kz440 LTD kickstart
- Billeuze
kz440 LTD kickstart
29 Mar 2026 21:38 - 29 Mar 2026 21:43
This is something I did 15 years ago. I believe it is well known that the kickstart internals from a 1979 kz400 fits the kz440. Yes, it just bolts right in
but that spring kept wanting to pop out of the hole so found something the right size (a piece of brake line I think) to make a sleeve that solved the problem
but make sure to use '79 parts. the gear I bought from ebay was listed with the '79 part number but clearly, with 23 teeth it is not a '79 and it doesn't mesh properly with the transmission gear. I only learned this when putting the case 1/2s together and they wouldn't close up because the gear didn't fit
The correct one (on the right) has 20 teeth
And for my bike, that was the easy part because mine is a late model year (1983) with the clutch actuator on the right hand side so it is not possible to use the side cover from a 400. So I had to use my side cover and there is no boss or support for the kicker shaft:
And it seems I am not allowed to fitt all my photis in one post so, continues next post...
Last edit: 29 Mar 2026 21:43 by Billeuze.
- Billeuze
Re: kz440 LTD kickstart
29 Mar 2026 21:39 - 29 Mar 2026 21:45
... continuing:
so, make a template where the kicker shaft goes and mark it on a chunk of scrap aluminum, cut it out, clean it up and make it fit:
Last edit: 29 Mar 2026 21:45 by Billeuze.
- Billeuze
29 Mar 2026 21:46
... continuing and finishing:
did some polishing while waiting for the correct 20 tooth gear to arrive
The kicker shaft support part I made I basically glued it on to the cover using RTV sliicone
And here it is still working (and not leaking oil) after 15 years and 50,000 km
The following user(s) said Thank You: asphalt900, MFP-Joe, Wookie58
30 Mar 2026 19:14
Nicely done.
- asphalt900
31 Mar 2026 01:29
Cleaver adaptation!! Almost time to polish those covers again haha. I have a Friend with a belt drive 440 slated to bring it over shortly. I know those drive belts have been discontinued for some time, know anyone that sells/makes a suitable copy that fits correctly?
- Nerdy
31 Mar 2026 08:51 - 31 Mar 2026 09:23I know those drive belts have been discontinued for some time, know anyone that sells/makes a suitable copy that fits correctly?
I have found a couple in really good shape on eBay, but they're not always available.
Oddly enough, the closest new item I've been able to find is a belt from an early 2000s Sportster. The KZ belt has a 14mm tooth pitch, 125 teeth, and is 1.25" wide; the Harley belt is the same except it's 1.125" wide (1-1/4" vs 1-1/8"). I don't know if the missing eighth of an inch is likely to cause any issues.
Note: there are also 129T belts for KZ440s but I'm not sure when/where they were used. I think it may be related to the two different rear pulleys that were/are available: one has four spokes and the other has five. According to Partzilla, the five-spoke pulley (part number 42041-5002) has 60 teeth but offhand I don't know how many the four-spoke one has. (Got 'em both in the basement - haven't counted the teeth yet
OTOH also according to Partzilla both types were used on all 440 D models, so... I dunno
EDIT: on eBay right now there is a four-spoke pulley that is described as "65T", so maybe the four-spoke requires the 129T and the five-spoke requires the 125T - ??? (I don't believe there were multiple versions of the front pulley, so they all should be 24T)
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
Last edit: 31 Mar 2026 09:23 by Nerdy.
- Billeuze
01 Apr 2026 00:41
Well I had no idea that a sportster belt might fit. I used to get replacements belts used on eBay. Last time I broke a belt I replaced it with my last spare and could not find any more used ones. So I ordered a chain and sprockets. When this last belt gives out I’ll switch to chain.
I have gone through 4 or 5 belts in the last few years. Of course my belts were all used and on top of that were forty year old rubber. They just don’t have what it takes to last. Belts are nice until you have to replace them. Removing the swing arm is no fun -especially if it hasn’t been removed in forty years. The first time I removed mine I had to destroy the swing arm axle just to get it off.
- asphalt900
01 Apr 2026 02:08
Great Information to know Nerdy, think Bill Liked it too!! I don't know what my Friends 440 combination of pulleys has on it? Will have to wrestle with that task when it arrives.
01 Apr 2026 02:13I think condition and maintenance is everything, we managed three seasons of this kind of abuse without breaking a single belt (Buelle X1, HD-FXDX with screaming eagle stroker kit and a V-Rod)Well I had no idea that a sportster belt might fit. I used to get replacements belts used on eBay. Last time I broke a belt I replaced it with my last spare and could not find any more used ones. So I ordered a chain and sprockets. When this last belt gives out I’ll switch to chain.
- MFP-Joe
01 Apr 2026 02:29
Wow, Wookie,... are you THIS pictured stuntdriver, or member of this team???? Impressing!!!
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
Z1000 A2 1977
Greetings, Joe
- asphalt900
01 Apr 2026 02:53
Is this how you're going to treat your KZ when you get it finished Wookie haha.
01 Apr 2026 03:10I just turned the spanners Joe, Craig Jones was the rider(we also did a nitrous Buelle that he used to set a record of 148.7mph on a frozen lake in Sweden)Wow, Wookie,... are you THIS pictured stuntdriver, or member of this team???? Impressing!!!
