650/750 engine in Z1 frame?
  • Sixten
  • Sixten's Avatar Topic Author
12 Jan 2026 08:32
#920574
Hi,
I found a Rickman frame Z1 without engine for sale and i have bunch of Z650/750 engines…
Would it fit with adapters? I don’t want to cut the frame.
  • MFP-Joe
  • MFP-Joe's Avatar
  • forever 18 when on my bike
Re: 650/750 engine in Z1 frame?
12 Jan 2026 08:39 - 12 Jan 2026 09:02
#920575
The "engine conversion specialists" here can certainly tell you that... If I were you, I would get a Z1000 A1 or A2 engine for the Rickman frame (they aren't as expensive as the 900cc Z1 engines, and they fit just like a 900cc engine; the dimensions are exactly the same).........Unless you enjoy challenges and are looking for the fun of remodeling...
Greetings, Joe
Last edit: 12 Jan 2026 09:02 by MFP-Joe.
  • sf4t7
  • sf4t7's Avatar
12 Jan 2026 08:56
#920577
I'm with Joe.  Why not drop in a 1000 - it fits perfectly and you'll have some extra power.  More if you hotrod the 1000 with a little more compression!
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • Injected
  • Injected's Avatar
12 Jan 2026 09:35 - 12 Jan 2026 09:42
#920580
I did the exact opposite and put a Z1 engine in a 650 frame without major alterations so I would say yes its probably going to work.
www.kzrider.com/forum/11-projects/618809...00-engine-transplant
If you read thru my build thread all the frame mock up is explained in detail.
The 650/750 engine is not as tall so there would be extra room at the top of the cam cover. Its much easier to do the mock up with empty cases/head/barrels, that is what I did. For mine I just sat the cases as low as possible then started looking at the motor mount points.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
Last edit: 12 Jan 2026 09:42 by Injected. Reason: more info
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
12 Jan 2026 10:06
#920581
Try and keep as straight a line as possible from the rear axle, through the swingarm pivot to the gearbox sprocket
The following user(s) said Thank You: Injected
  • Sixten
12 Jan 2026 12:20
#920586
Yes a 1000 would make sense but to race it it needs to be a Z1 or 650/750 engine.
Can the 650/750 engine be longer because of the extra shaft between the crank and gearbox?
  • TexasKZ
  • TexasKZ's Avatar
12 Jan 2026 13:31
#920589
What extra shaft?
  • Sixten
12 Jan 2026 15:38
#920593
The secondary shaft between the crank and gearbox. Chain driven from the crank and drives the clutch basket.
On Z1 engines the clutch basket drives directly on the crank.
  • Sixten
12 Jan 2026 15:57
#920594
The 650/750 engine is not as tall so there would be extra room at the top of the cam cover. It’s much easier to do the mock up with empty cases/head/barrels, that is what I did. For mine I just sat the cases as low as possible then started looking at the motor mount points.
Thanks. And nice build.
Looks like the length is similar but like you say I would have more space upwards and could probably rotate the engine to fit.
  • Injected
  • Injected's Avatar
13 Jan 2026 07:50
#920612
I never really put a tape measure on the two different engines, but there did seem to be some difference on the fore aft location of the front sprocket when I went to install the chain.
One tip I do have is to make sure you can slip the sprocket cover on when doing the mock up. On first try my shift shaft was too close to the bottom frame rail to get the cover to install.
  • zed1015
  • zed1015's Avatar
13 Jan 2026 11:38
#920627
650/750 engine is smaller/shorter in all directions compared to the 900/1000/1100.
  • StreetfighterKz
  • StreetfighterKz's Avatar
13 Jan 2026 13:30
#920630
Setting dimensions and required fabrication aside, you don’t want to mod the frame yet what will happen to it if you crash while racing it?  It’s most likely not going to come out undamaged.
Just something to think about…my 2¢.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
