J motor Fitment
  • Formula264
  • Formula264's Avatar Topic Author
J motor Fitment
04 May 2025 10:31
#912102
We are now fitting the J motor and just a couple issues. I have tried search on this matter but can't find any information. It looks like I have to remove the lower engine mounting tabs on the frame to be able to get the rear mount to align on the J motor. Has anyone done this swap?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: J motor Fitment
04 May 2025 10:49
#912104
Could it be you have swapped the LEFT/RIGHT upper engine mounts???
The following user(s) said Thank You: Warren3200gt, Gdizard
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: J motor Fitment
04 May 2025 12:21
#912107
You will also need to add front lower mounts
The following user(s) said Thank You: Gdizard, Formula264
  • Injected
  • Injected's Avatar
Re: J motor Fitment
06 May 2025 06:38 - 06 May 2025 06:43
#912162
According to this picture you don't really need the lower or bottom engine mounts...
This is a reinforced KZ650 frame that zed1015 built into a lightweight racer.
Build thread here - z1ownersclub.co.uk/phpBB3/viewtopic.php?f=7&t=14312&start=30
A drag bike frame builder also told me the most important engine mounting points for any KZ are the rear case mounts, that is where all the power and twisting is transmitted from the chain and sprocket.
When I put my Z1 engine into my 650 frame I made extra thick rear upper mount mount plates to replace the thin stock ones and gusseted the mount under the front sprocket.
1978 KZ650B2 modified project
Last edit: 06 May 2025 06:43 by Injected. Reason: info
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: J motor Fitment
06 May 2025 06:50 - 06 May 2025 07:01
#912163
I'm going to disagree with you on this one !!  Zed's bike is a modified 750Zephyr frame (as per previous BOTM feature) but also it uses a "pre-"J" motor. The "J" uses the three points in green (doesn't have a rear lower case mount) and the earlier motor uses the three points in red. If you could get hold of the cross member with the mounts from any "J" motored bike it would make things easier and stiffen the frame. See attached pic of Lee's "J" powered 650 and the three motor mount locations
Last edit: 06 May 2025 07:01 by Wookie58.
The following user(s) said Thank You: Formula264
  • Injected
  • Injected's Avatar
Re: J motor Fitment
06 May 2025 07:03 - 06 May 2025 07:07
#912164
My mistake, I thought they had a rear lower thru mount. Nothing a little welding and fab could not solve, the shop where those pics were taken looks pretty capable.
Last edit: 06 May 2025 07:07 by Injected. Reason: info
  • zed1015
  • zed1015's Avatar
Re: J motor Fitment
06 May 2025 07:08 - 06 May 2025 07:40
#912165
Last edit: 06 May 2025 07:40 by zed1015.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: J motor Fitment
06 May 2025 07:28 - 06 May 2025 07:50
#912166
Rob what am I missing ? - I don't see how you could use the same three points as your bike when the "J" motor doesn't have anywhere to attach the "lower rear" mounting point to ?????
Last edit: 06 May 2025 07:50 by Wookie58.
  • zed1015
  • zed1015's Avatar
Re: J motor Fitment
06 May 2025 07:58 - 06 May 2025 07:59
#912167
Forget my previous ( now deleted ) ramblings.
It was the result of a very rare brain fart which mixed up the details of both J motor into Z frame and vice versa  .
The soild bush conversion for the front mounts is still recommended though.
Last edit: 06 May 2025 07:59 by zed1015.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: J motor Fitment
06 May 2025 08:03
#912168
You completely confused me with that one buddy (not difficult) having been intimate with my "K" for nearly 3 years now you put me in a "tailspin" - how much more vibration do you get with the solid mounts ?
  • Injected
  • Injected's Avatar
Re: J motor Fitment
06 May 2025 10:22 - 06 May 2025 10:25
#912172
Not sure about a 1000 but my '82 750 engine I converted from rubber mount to solid mount vibrates about the same as a stock 650 bumped up to 831cc, hardly noticeable.
I thought the J1000 might have had the rear lower mounts recessed like the front lower ones, that is the way they have them on the later 750's (just thought I could not see them in the pics)
Last edit: 06 May 2025 10:25 by Injected. Reason: info
  • zed1015
  • zed1015's Avatar
Re: J motor Fitment
06 May 2025 10:31
#912173
It's not noticable, just the same as a normal Z.
