Cylinder Head Identification
- Injected
20 Oct 2023 15:59
I don't know much about the big bike parts. Trying to find out if this cylinder head is Z1, KZ900, or KZ1000. It has the number "62" stamped on the exhaust side next to the cam chain tunnel.
Any help would be appreciated.
1978 KZ650B2 modified project
Re: Cylinder Head Identification
20 Oct 2023 16:31
I know nothing...but that looks to me like an earlier head...that's been ported, and modded for big cams. Hopefully, you have the cam caps too.
- Injected
20 Oct 2023 17:02Yes, I had it ported by my local engine guy, and I cleared it for the cams. He thought it was Z1 but he said that he is no expert to ID what year etc.I know nothing...but that looks to me like an earlier head...that's been ported, and modded for big cams. Hopefully, you have the cam caps too.
I have the cam caps so no issues there. Just thought I should find out the lineage because people are bound to ask.
- sf4t7
20 Oct 2023 21:01
I don't think the "62" is factory stamping (I could be wrong) and if what's left of the black is original it's probably 73 Z1
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
- daveo
- zed1015
21 Oct 2023 02:34
If the vac port castings under the inlet ports are undrilled and the gallery plugs are alloy it's early Z900.
The following user(s) said Thank You: Injected
- slmjim+Z1BEBE
21 Oct 2023 04:29 - 21 Oct 2023 04:47
If the exhaust studs are 6mm it's Z1. If they're 8mm it's KZ1000.
The paint condition sure looks like OEM black from '72 - '73 manufacture with expected age patina, but that's pretty subjective.
If it's a Z1 head, detailed pics of the sides, top down at the #1 and #4 plug areas at about a 45 deg. angle, and underside with a good view of the intake castings would be necessary to ascertain how early in production it is, wherein in addition to the vacuum port bosses that Zed1015 mentioned, Mama Kaw made subtle changes in machining at the four outer stud hole areas & minor changes to the top fin castings between the cam towers above the #1 and #4 combustion chambers.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Last edit: 21 Oct 2023 04:47 by slmjim+Z1BEBE. Reason: Testing editing.
21 Oct 2023 06:55
Has to be a Z1. I see vacuum port bosses. Drilled or not is a Z1.
- Injected
21 Oct 2023 07:03
It has the blank port bosses under the intake runners and alloy end plugs.
The pictures are after using some of that Eco paint stripper, it needs another application.
I will post some pictures of the fin area, ends, and bosses later today.
- Injected
21 Oct 2023 08:37 - 21 Oct 2023 08:40
Here are some better pictures uncompressed.
The head has been big valved (37/31mm) and ported to 96/73 CFM for use with .420" lift cams.
This head came on a used KZ1000 engine I bought, the barrel on it was a 903cc but it had been fitted with 1015cc pistons.
Here are pictures of the cam cover.
I ground the "+" ribs out of the inside of the cam cover.
Last edit: 21 Oct 2023 08:40 by Injected. Reason: info
- sf4t7
21 Oct 2023 11:48 - 21 Oct 2023 11:50
My apologies to Injected. I was mistaken (not the first time) - I took a closer look at my spare 1974 Z1a head and it is stamped "48". So the stamping on yours is likely done at the factory.
And that valve cover is from a 900
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
Last edit: 21 Oct 2023 11:50 by sf4t7.
21 Oct 2023 21:33
Cam cover I a very early version. The circle with an A inside followed by a number 1. So it matches the Z1 head. Nice stuff!
