Mac exhaust??
15 Jul 2006 02:11 #62112 by gpzrox
Replied by gpzrox on topic Mac exhaust??
Draco wrote:
I emailed the seller, and he says that if the bike is in good running order (which it is) then I should not need to do a re-jet. I'm not sure I totally believe that. From everything I have read on this site, you pretty much HAVE to do a re-jet when you go with a less restrictive exhaust. Any opinions on this?
I an also planning to wrap the headers down to the mufflers, would doing so make any difference besides heat retention?
Thanks for the input guys, keep it comming!
I have heard of header wrap retaining mosture, rusting the pipes prematurely. NO personal experience here. The look is absolutely cool though.
The rejet is a good question. The question is how much less restriction you have with the new pipes: it may not be that much, or enough to justify a rejetting. That being said, even alot of totally stock bikes could use a rejetting being that they were lean runners from the factory. For example, jet kits are made for my bike in stock configuration, and supposedly give good bang for the buck (I think they are K&N stage 1's?).
I personally don't think that a pipe will cause major jet changes for my bike, but when I test fitted pods, WOW! I really needed to bump them up.
Expect to get a jet kit, research it and have the cash available. Then if you don't need it, use the money for something else.
84 GPZ750. Modded with stock Kawasaki parts: ZR-7 shock, ZX-6 coils, GPZ1100 throttle, EN454 brake, GPZ900 fuse box, etc. and non stock: Ken Sears mirrors, K&N filter, Pirelli Sport Demons.
