Crankshaft difficult question.
  • MLMG
  • MLMG's Avatar Topic Author
  • See you in the wind.
04 May 2023 17:06
#884240
I am about to buy a KZ A1 crankshaft with a bad connecting rod, is it possible to get a new connecting rod?
Can it be replaced by one of klx or klr?
thank you
1977 Kawasaki KZ1000 A1
  • TexasKZ
  • TexasKZ's Avatar
Re: Crankshaft difficult question.
04 May 2023 17:19
#884241
The following user(s) said Thank You: MLMG
  • Nessism
  • Nessism's Avatar
04 May 2023 17:26
#884243
You should send the crank to Stan Gardner in Maine or Pearson in Ohio for a full rebuild.  It's NOT cheap, but both those guys will have good used rods to include in the rebuild, and their reputation is above reproach.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
04 May 2023 23:18
#884257
Ed the problem is Leonardo is in Uruguay so he needs to think "outside the box", also importing "used" parts is illegal in his country
  • Mikaw
  • Mikaw's Avatar
05 May 2023 12:02
#884284
Is exporting? If not, could it be claimed as new once repaired?
The following user(s) said Thank You: Wookie58, MLMG
  • MLMG
05 May 2023 15:30 - 05 May 2023 15:37
#884294
The easiest way to get a crankshaft would be through those who import auto parts and declare it as a car crankshaft, although this has its risks.
Anyway, I'm going to buy the crankshaft since it is very cheap, it only costs 100 dollars.
I found the bearings in Japan, but not the connecting rods.
japan.webike.net/products/21852478.html
To give you an idea, there are only eight Kawasaki A1/A2 in the entire country of Uruguay.
Last edit: 05 May 2023 15:37 by MLMG.
  • DFIGPZ
  • DFIGPZ's Avatar
09 May 2023 14:59
#884450
MLMG
 rods were not serviced seperate from Kawasaki, Crankshaft sold ass assy, now you can send to rebuilder to tear apart & check it then reassemble and weld, I expect this is from 1977- 1980 KZ1000 [ 1015 ] Engine ? I have a set of brand new take off connecting rods from a NOS "J" motor KZ1000 [ 903 ] engine these will fit the 1015 crank but you would have to mill .040in off block to maintain your current compression ratio, these rods were pulled from NOS new "J" crank so it could be fitted with 83/84 GPZ 1100 rods if interested I will let them go ?
1984 750 Turbo
  • Mikaw
  • Mikaw's Avatar
09 May 2023 15:27
#884452
MLMG
If MLMG does not take the rods I’d be interested. I have a 81 J crankshaft with a bad rod. Are your 1024 numbers rods?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
09 May 2023 15:39 - 09 May 2023 20:00
#884453
A KZ1000J engine has 998 ccm: 69,4 mm bore and 70 mm lift but 1,2 mm shorter rods (piston to small end rod pin position 1,2 mm lower).
Edit: Stroke/lift is 66 mm!
Last edit: 09 May 2023 20:00 by Scirocco.
  • Nebr_Rex
  • Nebr_Rex's Avatar
09 May 2023 17:18
#884456
Scirocco, It's 66mm stroke .
(A KZ1000J engine has 998 ccm: 69,4 mm bore and 70 mm lift )
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
09 May 2023 19:57
#884462
Stupid me!!! You are right, it´s 66 mm stroke.
  • MLMG
10 May 2023 19:14
#884504
