new piston problem
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
Re: new piston problem
12 May 2023 06:52
#884546
To be honest if you take your time, use plenty of lube, make sure the ring end gaps are correctly positioned and don't "force" anything you should be fine. I would tend to agree that "too little" clearance is unlikely and a little excess will only result in reduced compression and possibly a little smoke from the exhaust. Be careful with your carb assembly so there are no air leaks and if it doesn't "feel right" stop. Giving it a good "thrashing" will never resolve issues  - (although it may make you feel better at the time)
  • 82KZ305Belt
  • 82KZ305Belt's Avatar Topic Author
12 May 2023 10:09
#884548
haha...I'm not a thrasher.  The carbs are one thing I'm very experienced at, having done far too many times.
But now JBM is suggesting my brand new (14 miles) slider rubbers may have swelled from exposure to ethanol in fuel...they are not snug on the slider and I certainly never used carb cleaner near them. Only 14 miles on them....but they fall right off the slider with hardly a touch. It never ends. TBH I don't know if there is ethanol in my fuel but I only buy it at on place so I will check.
Nope, just called em there's no ethanol in the fuel I use.
81 KZ650 CSR
77 KZ650B (not in my paws yet)
82 KZ305 CSR
