NEW BATTERY WON'T START THE BIKE
  • aquaholic
  • aquaholic's Avatar Topic Author
  • 1981 KZ1000 J1
03 Mar 2023 15:01
#881058
OK guys, 1982 KZ1000J,  got a new battery a year ago 310CCA. Charged it and it won't turn it over enough to start the bike. A car battery rolls it over fine. I did rebuild the starter last year and haven't used it enough to wear it out lol. Engine is tight after a rebuild. Any ideas where I can get a higher cranking amp battery without giving up my first born child. Any other thoughts as to what is causing the problem are always appreciated.
  • Bogie1
  • Bogie1's Avatar
Re: NEW BATTERY WON'T START THE BIKE
03 Mar 2023 15:17
#881060
Did you have the Battery load tested? the  battery could have gone bad after a year,
my battery is about a year and a half old and it is junk. I have also been looking for a new battery ,and have not seen anything with a larger cca then what you have.
Mike Bogos
1978 Kawasaki 1000 LTD
1977 Kawasaki KZ1000 Project
1982 Suzuki 1100 L
1971 Rupp Roadster
1965 Olds 442 Conv
1970 Olds 442 Conv
The following user(s) said Thank You: aquaholic
  • Nerdy
  • Nerdy's Avatar
03 Mar 2023 15:24
#881061
Dude, typing in ALL CAPS is the electronic equivalent of shouting. You don't need to shout. :)
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
  • aquaholic
  • 1981 KZ1000 J1
03 Mar 2023 15:54
#881062
It was only in the subject line. Sorry if I offended you
  • aquaholic
  • 1981 KZ1000 J1
03 Mar 2023 16:12
#881063
I load tested it and it appears to be fine. Starts out at 12 volts and drops to just above the bad line lol. Maybe I should just get another one. I hate throwing money away
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
03 Mar 2023 17:02 - 04 Mar 2023 00:56
#881065
Charge it fully then connect a voltmeter red lead to battery positive and black lead to the positive terminal on the starter. Operate the starter and Let me know what you get ( should be no more than 0.5v)
Also connect across the battery with the voltmeter, what is the voltage static and what does it go down to when you operate the starter (should be no lower than approx 9.5v to 10v when cranking)
Last edit: 04 Mar 2023 00:56 by Wookie58.
  • aquaholic
  • 1981 KZ1000 J1
03 Mar 2023 17:17
#881066
I'll let you know and thank you..probably be Sunday
  • Nerdy
  • Nerdy's Avatar
03 Mar 2023 17:18
#881067
Where did you get the battery? The ones I've gotten from AdvanceAutoZone have stickers on them to indicate the purchase date: I went to return one that was bad and it was actually still under warranty, which was a pleasant surprise. Maybe yours is still covered, or at least prorated so you won't have to pay full price for the new one (depending on how the test goes in the store).
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
  • F64
  • F64's Avatar
  • 81-KZ440D2
03 Mar 2023 20:22
#881074
You should be ok with with 310CCA.
The stock battery is only 235CCA.
How did you maintain the battery?
81-KZ440-D2.
LIC, NY
  • kevski
  • kevski's Avatar
04 Mar 2023 00:29
#881077
I have one of those batteries, fully charged doesn't turn starter, still showing full charge, bought a new battery, job done, proves it can show full charge and still be foobarred.
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
04 Mar 2023 05:33 - 04 Mar 2023 07:34
#881082
OP,
Is your battery a wet storage battery (conventional or AGM), or a LiIon battery?
LiIon batteries lose an increasingly significant fraction of their cranking power the colder they get,  because the internal resistance of LiIon cells increases as temperature decreases.  A quick & dirty way around that is to turn on the headlight(s) for a minute or so, then turning it (them) off and cranking again.  The current flow powering the light(s) warms the battery internally a little, reducing internal resistance of the battery some & allowing it to deliver increased current.  This has been fairly well documented on the Honda ST-1300 forums, possibly others.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
Last edit: 04 Mar 2023 07:34 by slmjim+Z1BEBE. Reason: Typos
  • aquaholic
  • 1981 KZ1000 J1
04 Mar 2023 06:25
#881084
AGM and thanks for the info.  Have a great weekend
