1982 kz 750e starter upgrade?
  • Ricco86
  • Ricco86's Avatar Topic Author
04 Nov 2022 07:57
#876371
Hi all,
I was wondering if anyone has replaced or upgraded the starter on their kz 750e. I rebuilt mine last year and the only parts I found were on Amazon of course aftermarket. The issue back then and now again is brushes worn out to the point of not starting. The commutator was slightly deformed and since couldn’t find a replacement I carefully file it while using a drill to spin it gently. This wasn’t the right way but kept me going and allowed me to ride for the season. Also Is the coil housing or sleeve should be smooth because mine isn’t
Ricco
  • zed1015
  • zed1015's Avatar
Re: 1982 kz 750e starter upgrade?
04 Nov 2022 08:03
#876372
Hi. Squaring up the commutator is best done on a lathe then cut back the mica between the segments.
As for replacement .
Any of the aircooled Z650/Z750  fours and newer aircooled ZR750 Zephyr starter motors will fit so it shouldn't be too hard finding a decent replacement as there's tons of them new and used on ebay.
The following user(s) said Thank You: Ricco86
  • Nessism
  • Nessism's Avatar
  • Away
04 Nov 2022 08:10
#876374
"Stockers" is the go to place for starter rebuild kits.  Your commutator is worn, but I've seen way worse run fine.
  • Ricco86
04 Nov 2022 08:11
#876375
zed1015,
thanks for the input. I will surely look into that way of making it smooth again. Also on the parts for the zr 750. It’s so hard to keep up with vintage parts tracking but it’s rewarding when everyone is always complementing it and asking to buy it. Will start searching now! Thanks again
Ricco
  • Injected
  • Injected's Avatar
04 Nov 2022 08:14
#876376
Don't put a starter in it from a kick start 650 (1977 to 1980) as they only have 2 brushes instead of 4.
Kw is the same but the later ones are somehow stronger as they only had that to start the motor.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
  • Ricco86
04 Nov 2022 08:18
#876378
Nessism
I appreciate that, for giving me hope to save this one for now, and for the site to find replacement parts
Ricco
  • Ricco86
04 Nov 2022 08:19
#876379
Injected,
I’ll avoid those when searching, and appreciate the heads up before opening another can of worms haha.
Ricco
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
04 Nov 2022 09:42
#876380
If you go the refurb route, once you have trued the commutator I have always found the best way to undercut the mica (needs to be below the surface of the copper so the brushes have full contact) is to break a hacksaw blade (don't forget to tape the broken end) and grind it thinner than stocky, you can then use this to carefully cut the mica back between the segments
  • Ricco86
04 Nov 2022 14:25
#876390
So this is how it looks now, I cleaned even better after the pic and cleaned the segments way better, but didn’t knew the hacksaw blade trick, I reassembled it to avoid contamination fall into the crankcase. Once I get the parts to rebuild I will do that trick
Ricco
  • riturbo
  • riturbo's Avatar
04 Nov 2022 14:41
#876393
If it still gives you problems my friend just had his rebuilt by these guys . Came back brand new and was only a little over 200 .  Heh ad it back in a week
ricksmotorsportelectrics.com/?fbclid=IwA...UylesV6NAV9ZjZAq5I8Y
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
  • Ricco86
04 Nov 2022 16:19
#876396
Riturbo
awesome thanks so much. Hopefully it works but definitely saving the link for a just in case. Maybe get one from the local junkyard if they still have one and maybe send it regardless as a backup since seems this starters are notorious for crapping out lol.
Ricco
The following user(s) said Thank You: riturbo
  • Injected
  • Injected's Avatar
06 Nov 2022 11:50 - 06 Nov 2022 11:51
#876477
Riturbo
"this starters are notorious for crapping out"
Where did you here that?
Kawasaki did not build items that broke easily, they were primarily a ship building company.
But like any company they did not intend there products to live for 30-40 years either.
I have a '82 starter in my bike and its never been apart.
Last edit: 06 Nov 2022 11:51 by Injected.
