KZ440 Engine Swap into KZ305 Bike.
  • KaosKontrol
  • KaosKontrol's Avatar Topic Author
Re: KZ440 Engine Swap into KZ305 Bike.
07 Mar 2023 23:57 - 07 Mar 2023 23:58
#881234
I have one of the trash ebay pistons and I have my old piston that grenaded on me. Which one would you prefer? Or I can just send both.
Last edit: 07 Mar 2023 23:58 by KaosKontrol.
  • Nebr_Rex
  • Nebr_Rex's Avatar
08 Mar 2023 18:02 - 08 Mar 2023 18:14
#881267
The ebay piston.
E mail me for my address.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Last edit: 08 Mar 2023 18:14 by Nebr_Rex. Reason: Why is my pm not working?
  • KaosKontrol
09 Mar 2023 10:35 - 09 Mar 2023 11:05
#881301
Alright. I'm off Monday so I'll do it then. Not sure how to email you through here though.
Last edit: 09 Mar 2023 11:05 by KaosKontrol.
  • Nebr_Rex
  • Nebr_Rex's Avatar
10 Mar 2023 16:13
#881358
Check my profile.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • KaosKontrol
10 Mar 2023 23:18
#881369
Checked your profile and didn't see any email or PM options for you. Still somewhat new to using this forum. I might just be missing it.
  • Nebr_Rex
  • Nebr_Rex's Avatar
11 Mar 2023 16:40
#881389
blr44x at yahoo dot com
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • KaosKontrol
13 Mar 2023 21:23
#881476
Email sent
  • 82KZ305Belt
  • 82KZ305Belt's Avatar
18 Mar 2023 11:00
#881692
I've been down this road before with the KZ400/440s.
Do you have a piston you could send me?
I can take some measurements and see what I can find.
You won't find anything. I've been looking for years. Would love to eat my words.
81 KZ650 CSR
77 KZ650B (not in my paws yet)
82 KZ305 CSR
  • 82KZ305Belt
18 Mar 2023 11:17 - 18 Mar 2023 12:49
#881695
Just fix the compression issue on the 305. Nothing else would be worth your while. If I really wanted an engine replacement, it would be a full-on project. Personally I'd go for one of the 454 or 500 water-cooled twins and try and make it fit. The 305s are quite rare now, I think. Much easier and cheaper to repair it than do anything else.
You've never tried to fix a compression issue on a 305 in recent years. New jugs are unavailable, 99% of used ones need rebore, Oversized pistons are next to impossible to find in pairs, only one comes up every couple years. I've checked overseas, underseas, in the sky, cross-compatibility and nothing, zilch zip nada. There was a new 1.0 on ebay for a while (might still be) but he wanted $140 for it and one doesn't do anyone any good. You'd pay that much again for 1.0 rings, if you found em, and still be a cylinder short
 KaosKontrol post=866850 userid=62324 said: I'm not skilled enough to rebuild the engine myself
yes you are, if you can find the parts. I've never rebuilt anything bigger than a toaster and with the help of this site I rebuilt my top end (farming out the valve/machine work). Unfortunately it ended not being enough because the cylinder was a tad too scored, but it did run when I put it all back together. Wouldn't go above 45 tho and blew smoke. For the same reasons you are stuck, mine has been stuck 2 years waiting to find parts. So you can definitely do it.
81 KZ650 CSR
82 KZ305 CSR
Last edit: 18 Mar 2023 12:49 by 82KZ305Belt.
  • KaosKontrol
13 Apr 2023 21:33
#883093
Yeah, no. I'm too heavy handed with wrenches so I don't do much more than basic maintenance and the occasional redneck ingenuity fix if I get stuck out in the middle of nowhere. Aside from that, I will usually get a shop to do it if I can. If it was an iron block I wouldn't be so apprehensive about wrenching on the internals but it ain't an old Chevy so I'd most likely make it worse.
