Checked valve clearance this morning.
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
Re: Checked valve clearance this morning.
18 Apr 2022 19:58 - 18 Apr 2022 20:07
#865724
Zip-tie or tie-wire the cam chain to the cam sprockets so they don't lose their position and then roll the cams one at a time off to the side so you don't lose its position off the bottom gear. Works a treat.
The procedure is detailed here.
www.riderforums.com/threads/zr-7s-valve-...t-with-pics-1.52880/
Last edit: 18 Apr 2022 20:07 by blipco.
The following user(s) said Thank You: Steel Legion
