Stubborn cylinder #2 - Can't figure it out!
- gd4now
- Denco where did you go?
Re: Stubborn cylinder #2 - Can't figure it out!
24 Aug 2021 19:48
I have read and have done so on small engines (lawn mower, rototiller etc) made use of rope feed into the spark plug hole to hold the valves closed, but the proper way is to remove the head and make use of a clamp to hold it closed.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- richard
01 Sep 2021 18:41
There was no mention of smoke
Does it do it constantly or just initial start up?
Also are you the original owner
And did this just start with the cooler cylinder ?
- jekyllman
04 Sep 2021 15:54
Now that it's "running" I'm getting smoke during idle and some throttle as well. It's only coming from the left exhaust and it's cylinder #2 so it's my assumption it's the cause as well of the smoke and oil dripping from that exhaust drain.
Not the original owner.
1980 KZ650F1 - 10k miles (see photo)
1981 KZ305 CSR - 10k miles (didn't have the heart to customize this one, will stay original)
- Kaylinator
19 Sep 2021 00:11
Do a compression test on cylinder 2. Note the reading.
Add a small amount of oil in the spark plug holes (teaspoon or so). Do another compression test.
If your compression increases, you need at least a hone and new rings. If it doesn't change, valve seals, possibly guides.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
1978 KZ400-B1
2022 Z900RS SE
