KZ440 Speed / RPM / Gearing
  • TexasKZ
  • TexasKZ's Avatar
Re: KZ440 Speed / RPM / Gearing
03 Aug 2021 21:00
#853122
I know I can use a phone to measure GPS speed.  What other way could I measure RPM?
With a calibrated tachometer. In the olden days, mechanics routinely used a device called a tach / dwell meter when tuning up cars with points ignition. The one I have is getting close to 50 years old. I have no idea if anybody still sells one, but if you can buy, borrow or rent a decent one, you can use it to compare the bikes tachometer readings.
  • TexasKZ
  • TexasKZ's Avatar
03 Aug 2021 21:02
#853123
Well, they do indeed exist. A two second search netted a ton of them.
www.amazon.com/dwell-tach-meter/s?k=dwell+tach+meter
04 Aug 2021 03:18
#853129
Maybe your bike's clutch is slipping.  Ed
What makes you say that?
I've seen where folks have bikes that run at high rpm and they eventually find that the clutch was slipping.  When that happens it is not unusual for the rpm to exceed normal speeds to keep the bike moving along at a given pace.  Ed
  • KZB2 650
  • KZB2 650's Avatar
04 Aug 2021 07:21
#853135
From what I've read I'd try a 16 tooth front. Read it lowers things by 400 R's at 60. Would be cheap and you could still go with a 42 rear if you needed too. Would give you a idea what it might do for around town power and fun before you spent too much also.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • SteveKing84
  • SteveKing84's Avatar Topic Author
06 Aug 2021 18:02
#853301
A slipping clutch could account for the higher than expected rpm at highway speeds.
How can I check for this.  This certainly is not something I want happening!
  • SteveKing84
06 Aug 2021 20:22
#853312
Is it my fault because I like to adjust my clutch engagement closer to the grip than not?
