no compression
  • F64
  • F64's Avatar
  • 81-KZ440D2
Re: no compression
04 Aug 2020 07:18
#832208
When you did your compression check did you fully open your throttle?
Also, pull the fuel pump and fuel injector fuse when you do a compression check. You don't want fuel being pumped into the cylinder during the test. If you have a spark and your spark plugs are pulled out, you'll have a nasty fire. Plus, the raw fuel will wash the oil off of your cylinders.
81-KZ440-D2.
LIC, NY
