Clicking From Engine Pulley?
  • ERIK814
  • ERIK814's Avatar Topic Author
23 Jun 2020 19:26
#828804
Engine pulley started to make a clicking noise when rotating after a long ride this last weekend with pillion & luggage. First I thought it might be the belt not catching the pulley right due to gunk, so I cleaned the belt with mild soap and water. After that didn't work, I loosened / tightened the belt, and tried to rear alignment to either side to see if it was an alignment or tension issue but no luck. I took the pulley cover off and think that maybe it is the pulley itself that is clicking. Before I take off the belt entirely to confirm it's not the belt, I wanted to check to see if anyone had any ideas. Here is a video of the clicking:
photos.app.goo.gl/QR5EaDdZ1yW9cBb76
Thanks all!
1981 KZ 440 LTD Belt Drive (Late Model)
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Clicking From Engine Pulley?
24 Jun 2020 02:38
#828816
Sounds like the main bearing of the output shaft is shot. Part# 92045
The following user(s) said Thank You: ERIK814
  • ERIK814
24 Jun 2020 13:54 - 24 Jun 2020 18:47
#828899
Yikes! That seems deep in there. From what I can tell, the engine will need to be taken off the bike and the case split to replace the output shaft drive bearing...
Is it possible to keep riding on it with a spent bearing? Has anyone been able to replace the bearing without splitting the engine? I'm trying to figure out if this is even worth trying to fix. I don't have a ton of space to work on this and as a very novice mechanic I'm worried I may be in over my head.
Last edit: 24 Jun 2020 18:47 by ERIK814.
  • VTEC
  • VTEC's Avatar
25 Jun 2020 08:42
#828957
Looks like you can pull the sprocket, pop out the output shaft seal, and get a direct view of the bearing balls. Then rotate to confirm that's the problem.
KZ1000-K2
ZRX1100
XR400R
  • ERIK814
25 Jun 2020 10:25
#828961
I'll give that a try - thanks for the tip! This will require me to take the belt off, so at least that will help me confirm it's not the belt!
  • ERIK814
29 Jun 2020 19:50 - 29 Jun 2020 19:55
#829403
I took the rear tire off / loosened the belt and the no sound at all when rotating the pulley. It felt smooth, no sign of leaky oil or anything. I noticed that when I pushed hard on the pulley toward the rear wheel to simulate belt tension, there was a slight clicking when rotating he pulley!
I tried to tighten the pulley bolt and I think the nut may have rotate rotated slightly, but it is difficult to confirm because I don't have a holder. I tried to push on the pulley and rotate it after attempting to tighten it and I didn't hear anymore clicking. But when I got the belt back on and set the tension, the clicking came back.
Is it possible that a loose nut on the engine pulley could be the reason for the click? I'm 99% certain I was not able to tighten it to the 60+ lb-ft needed to be in spec. Or does this sound more like a damaged output shaft drive bearing?
Thank you in advanced for any help / advice!!
Last edit: 29 Jun 2020 19:55 by ERIK814.
  • VTEC
  • VTEC's Avatar
30 Jun 2020 16:18 - 30 Jun 2020 16:22
#829463
If the bolt was loose it certainly can cause the noise. Get a holder and torque to specs. Or maybe you can catch a tooth with a pry bar against something safe.
No help, pop the seal and look at the bearing.
KZ1000-K2
ZRX1100
XR400R
Last edit: 30 Jun 2020 16:22 by VTEC.
  • ERIK814
09 Jul 2020 14:52
#830222
I tried the 6th gear / rear brake trick and it worked! Girlfriend held the brake while I cranked with the torque wrench. Didn't seem to be an issue at all for the belt to hold. Got the nut to 61 lb.ft per spec and it definitely turned a little bit during the adjustment. No more sound from the pulley when rotating by hand, BUT I still need to ride it around a bit to confirm.
I'll provide an update if the issue comes back but for now it is solved! Thanks again everyone for your help.
  • VTEC
  • VTEC's Avatar
09 Jul 2020 15:21
#830225
Is there a washer with locking tabs behind the nut? I know there was a recall in that time frame to add the washer and prevent the nut backing out.
KZ1000-K2
ZRX1100
XR400R
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
09 Jul 2020 15:24
#830226
Can´t belive that re-torquing your pully would solve your clicking noise on a longer preiod, Arnie would say: "I´ll be back."
  • ERIK814
09 Jul 2020 15:55
#830227
There is a washer with locking tabs behind the nut, but they obviously didn't stop the thing from coming loose or being able to be tightened again.
If you look closely at the image attached, the locking tabs are on the corner of the nut before I tightened it. After tightening the nut, the washer tabs lined up again with the edge of the nut. I probably should have squeezed them in more before putting the pulley cover back on. If the noise returns, I might do that or consider replacing the washer tab.
  • JD_1982
  • JD_1982's Avatar
11 Nov 2025 08:16
#918963
Hey ERIK814, my 1981 KZ440 LTD Belt recently starting developing the exact same symptoms: clicking from the engine pulley area when the wheel is rotated.  Here's a video showing the issue while I manually rotate the rear wheel:  applegategroup.sharefile.com/public/shar...458b87992b0f28814213
I was just curious if tightening down the pulley nut was a long-term solution for you, or if the clicking sound came back (possibly indicating that yes, the main bearing on the output shaft is failing).  Let me know!
