Oil weight for KZ550 LTD
  • TexasKZ
  • TexasKZ's Avatar
Re: Oil weight for KZ550 LTD
14 Jun 2020 12:21
#828164
During the summer months, 15w-40 will be just fine. If you later ride in cold weather, a change to 10w would be a good idea to insure full flow at startup.
The following user(s) said Thank You: Gdailey2112
  • VTEC
  • VTEC's Avatar
15 Jun 2020 17:56 - 15 Jun 2020 17:57
#828262
You.re in a moderate climate so the best way to go is the preferred weight 10w40. And as every body states, petroleum oil for a new engine, then switch to synthetic -- it's better. I use Mobil 1 racing 4T. It has the wet clutch additives and zinc for metal to metal valvetrains. Not cheap, but good stuff.
KZ1000-K2
ZRX1100
XR400R
Last edit: 15 Jun 2020 17:57 by VTEC.
The following user(s) said Thank You: Gdailey2112, ellipsesKZ
  • Gdailey2112
  • Gdailey2112's Avatar
  • 82 KZ1100D1
15 Jun 2020 18:44
#828264
It's so hot out there, I seen a dog chasing a cat, and they were both walkin'! lol
1982 KZ1100D1
