720cc kit for 11/78 z650C
- DFIGPZ
Re: 720cc kit for 11/78 z650C
13 Nov 2020 14:52
word of advise go ahead and put time cert in the center head bolt holes located under the valve cover and get 2 grade 8 allen head bolts to install in those 2 holes these always seem to strip no matter how careful you are when installing, nothing like having the head on and tightning the 2 center bolts only to have them strip !
1984 750 Turbo
The following user(s) said Thank You: Mc Tavish
- Mc Tavish
13 Nov 2020 20:03
Thanks for the heads up DFIGPZ. I will do that as I have read of others running into this problem.
Cheers mate.
Cheers mate.
1978 z650C
- KZB2 650
14 Nov 2020 04:52DFIGPZ wrote: word of advise go ahead and put time cert in the center head bolt holes located under the valve cover and get 2 grade 8 allen head bolts to install in those 2 holes these always seem to strip no matter how careful you are when installing, nothing like having the head on and tightning the 2 center bolts only to have them strip !
I remember worrying about these but left them alone and only went to the min torgue. One of them could a should a done things. Read so much on the cam caps I heli coiled all 16 of them though.............. (not recommending it though even though it went well)
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
