Cylinder drop
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
Re: Cylinder drop
30 Mar 2020 06:42
#822179
These are paired, "wasted spark" ignition systems, meaning that when #1 plug is sparked on the compression stroke, #4 is also sparked on the exhaust stroke, a useless or "wasted" spark. When #4 is sparked on compression, #1 spark happens on exhaust stroke. Ditto the paired #'s 2 and #3.
The plugs are electrically in series. Both have to spark in order for either to spark.
Ignition high voltage can behave in unexpected ways. Not sure of the spark voltage on Mama Kaw's dual coils, but probably somewhere in the neighborhood of 20,000 to 30,000 volts. A single plug wire can test good with a meter, but it's insulation can break down when the high voltage spark pulse is generated, allowing the spark to leak to ground (usually frame) through a tiny defect in the plug wire. That would cause both paired cylinders to drop simultaneously.
Examine the plug wires very closely in good light, maybe with a little magnification.. Look for a streak of white-ish ash looking stuff or, a circular ash corona around a pinhole that may or may not be easily seen. Also, with the motor running, move the plug wires around some, concentrating on separating them from any contact with ground; the motor itself or the frame. Also, don't forget to remove the plug wires from those straps on top of the valve cover if present.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
  • jdsteph0897
  • jdsteph0897's Avatar Topic Author
Re: Cylinder drop
31 Mar 2020 16:17
#822325
I ordered new plug wires and pickup coils. There’s not much else it could be. Did I mention I hate intermittent electrical problems!
  • slmjim+Z1BEBE
Re: Cylinder drop
01 Apr 2020 07:10
#822374
jdsteph0897 wrote: ... Did I mention I hate intermittent electrical problems!
The bane of a field Tech's existence. The source of many service recalls.
Tech never really knows if they solved problem until an indefinite period of time has passed.
Good Ridin'
slmjim & Z1BEBE
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
  • old_kaw
  • old_kaw's Avatar
Re: Cylinder drop
01 Apr 2020 07:51
#822382
Definitely verify constant B+ voltage to your coils.
1981 Kawasaki Kz1000K1
