78 kz1000ltd weird back pressure in oil system? 09 Dec 2019 17:51 #815142
  • seanbarney41
  • seanbarney41's Avatar Topic Author
  • '79 kz1000 LTD '75 Honda CB750
  • Thank you received: 23
Ok, here is what I did today....first I pulled the main gallery plug above the points cover. Oil film was present. Then I pulled the return hose off the cooler and blew compressed air. A little residual oil and air flowed freely into the main gallery. Then I pulled the input hose off the cooler and blew through. Air and oil flowed freely. Same with the hose from the pressure switch to the cooler.
Then I pulled apart the crankcase breather. I saw nothing abnormal here. I could see a bit of transmission and it was well oiled.
Then I pulled the oil filter. All was normal except the blown out oring...but is the filter bolt supposed to have a spring and check to act as a filter bypass? Like a honda? Well parts fiche does not show this and mine does not have anything.
Finally I removed the cooler adapter that returns oil to the main gallery. Perfectly clean and no obstructions. I tried to get the pressure switch send adapter off without removing carbs but couldn't get it. And I know oil went way past here anyway and now that I think back, I went all through these parts about a year ago before I installed the carbs.
78 kz1000ltd weird back pressure in oil system? 09 Dec 2019 18:04 #815143
  • seanbarney41
Oh yeah, I blew air into the pressure switch adapter and could feel it coming out where the filter seats. So still stumped....questions
1. Relief valve is in the pump?
2. Could this just be a bad filter? And something wrong with the reluef?
3. My hose to and from the cooler is 3/8...maybe too small, but could that cause problems like this?
Pics
78 kz1000ltd weird back pressure in oil system? 09 Dec 2019 18:07 #815144
  • seanbarney41
More pics
78 kz1000ltd weird back pressure in oil system? 09 Dec 2019 18:09 #815145
  • seanbarney41
Just had another thought...
My filter bolt seems too long. Could it be bottoming before the cover gets full tight?
78 kz1000ltd weird back pressure in oil system? 09 Dec 2019 19:02 #815148
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
  • Thank you received: 503
Scirocco wrote: Just for testing the oil flow i would made direct loop oil line and see if your back pressure happens again.
I was going to suggest the same thing.
Also, you could see if the local auto parts store (AutoZone, etc) will loan you an oil pressure tester like this. They often will loan tools for free.
www.harborfreight.com/Engine-Oil-Pressure-Test-Kit-62621.html
It can be connected in place of the galley plug on the right side to confirm that you have pressure after the cooler return line.
My dad's '74 Z1
'00 ZRX1100
Last edit: by DOHC.
78 kz1000ltd weird back pressure in oil system? 10 Dec 2019 06:16 #815159
  • KZB2 650
  • KZB2 650's Avatar
  • Thank you received: 265
seanbarney41 wrote: Just had another thought...
Maybe try a good fitting washer or "gently" try turning the cover as to not un seat the o ring just before it gets tight. Don't go too tight cause I've read of others cracking it by over tightening.
And is there a spring and some kind of vale inside this bolt ? Could this do something like this guys ? I've looked at mine before and really didn't know how it works or how to check that it is.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: by KZB2 650.
78 kz1000ltd weird back pressure in oil system? 10 Dec 2019 08:48 #815167
  • Zeerx
  • Zeerx's Avatar
  • Thank you received: 22
I saw the spring with the filter. Do you still have the washer? The washer will stick to the filter and thrown away with the filter.
‘99 ZRX1100, ‘05 DRZ400S, ‘78 KZ1000LTD, ‘12 F150 (Ford)
78 kz1000ltd weird back pressure in oil system? 10 Dec 2019 09:29 #815170
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
The spring can be used without the washer. I'd put it together, take off the inspection port fitting , fire it up and see if oil comes gushing out. It should take only a few seconds. If not shut it down and find out why.
78 kz1000ltd weird back pressure in oil system? 10 Dec 2019 09:37 #815171
  • seanbarney41
I had the washer up until the last disassembly. It is somewhere in my drain pan. All the washer does us protect the filter grommet from the spring.
Lots of things to try here, so thanks. I will update if I find something.
78 kz1000ltd weird back pressure in oil system? 10 Dec 2019 09:58 #815174
  • ned37
  • ned37's Avatar
  • Thank you received: 11
So still not sure why it could be blowing the o ring out. Could this be caused by lack of crankcase breathing
my old brain is fuzzy, but this is my bet
'83 GPZ1100, '97 Triumph Trophy 1200, '08 Husky TE610
Verde Valley, AZ
Last edit: by ned37.
78 kz1000ltd weird back pressure in oil system? 10 Dec 2019 10:34 #815176
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1899
Never ever will a gas medium (blowby pressure in a engine case) compress a liquid like oil.
Open your oil filler opening and you will not feel any over pressure.
78 kz1000ltd weird back pressure in oil system? 10 Dec 2019 13:30 #815182
  • seanbarney41
ned, I overhauled the crankcase last night and found nothing but the stone axe simple parts Kawasaki put in there...It's all wide open. What could go wrong with it? ...plus what Scirocco said makes perfect sense
