1981 KZ650CSR
  • Featherless
  • Featherless's Avatar Topic Author
1981 KZ650CSR
12 Sep 2019 15:39
#810767
I purchased this bike being told it ran just needed the carbs cleaned.
Way beyond this now.
I need Cylinder studs, when I look up the part they say 10 X 153, 10 X 133 and 10 X 116.
The ones I removed measured 10 X 180ish , 10 X 156 and 10 X 140
So I am at a loss here.
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • old_kaw
  • old_kaw's Avatar
Re: 1981 KZ650CSR
12 Sep 2019 16:19
#810773
SWest wrote: WHAT BIKE?
Going out on a limb here Steve.. Maybe a 1981 KZ650CSR? Just a WAG. (wild a$$ guess) :woohoo:
1981 Kawasaki Kz1000K1
The following user(s) said Thank You: Featherless
  • SWest
  • SWest's Avatar
  • 10 22 2014
The following user(s) said Thank You: old_kaw
  • Featherless
Re: 1981 KZ650CSR
12 Sep 2019 16:35
#810777
I got the numbers of bikebandit ut it would seem they all agree.
Also, I have to repair several threads on the case. Are heli coils cool or should I get threaded inserts.
  • TexasKZ
  • TexasKZ's Avatar
Re: 1981 KZ650CSR
12 Sep 2019 16:44
#810780
I wonder if they have been replaced with aftermarket studs from APE, MTC or such?
Re: 1981 KZ650CSR
12 Sep 2019 16:59 - 12 Sep 2019 17:02
#810781
Featherless wrote: I got the numbers of bikebandit ut it would seem they all agree.
Consider using Time-Serts rather than heli coils. Ed
www.timesert.com/
Last edit: 12 Sep 2019 17:02 by 650ed.
  • Featherless
Re: 1981 KZ650CSR
12 Sep 2019 17:16 - 12 Sep 2019 17:38
#810783
I just purchased timeserts kit. I use them at work often and better then helicoils.
Not sure about the other but they seem a real good fit. not too long but the right ones.
Can I put links here to parts?
They have a complete stud kit. wanted some expertise on this.
Last edit: 12 Sep 2019 17:38 by Featherless.
  • TexasKZ
  • TexasKZ's Avatar
Re: 1981 KZ650CSR
12 Sep 2019 19:35
#810789
Yes, you can put a link in your post. The longer ones are listed as still available from Kawasaki, but the short ones are listed as nla.
  • TexasKZ
  • TexasKZ's Avatar
Re: 1981 KZ650CSR
12 Sep 2019 19:35 - 12 Sep 2019 19:40
#810790
www.partzilla.com/catalog/kawasaki/motor...rankcase-81-82-h1-h2
Last edit: 12 Sep 2019 19:40 by TexasKZ.
  • gazzz
  • gazzz's Avatar
Re: 1981 KZ650CSR
13 Sep 2019 13:57 - 13 Sep 2019 13:58
#810815
I have my own reasons to use OEM cylinder studs. But as it was said, shortest stud are not available. Solution is simple. Kawasaki ZR-7 has cylinder studs of identical to KZ650 studs lengths: 116, 133, 153
www.partzilla.com/catalog/kawasaki/motor...s-zr750-h1/crankcase
Main visual difference is that ZR7 studs have factory applied thread locking compound on lower threads. I've ordered set of ZR7 studs. Hope to receive them on next Monday.
Kawasaki KZ650 cafe-racer: in progress
Kawasaki Zephyr 750 (810ccm, 4in4, spoked wheels)
Honda CB815 "Eight Fifteen" cafe-racer
Yamaha XJ "Eight Ball" cafe-racer
www.gazzz-garage.com
Last edit: 13 Sep 2019 13:58 by gazzz.
  • Featherless
Re: 1981 KZ650CSR
13 Sep 2019 16:59
#810821
Ok, this mess may have fixed a lot of problems.
I stripped 3 studs and broke one.
I only had 87 cylinder pressure. the book calls out 205 to 187 and 155 the lowest usable.
I wasn't half.
Not to mention after gauging out the head I found the shims were just thrown in randomly and never properly placed and one is nearly .080 oversized. I have no idea where it came from.
the exhaust valves were carbon over bad. the bike idled if I poured fuel over it by the quarts.
The needle bearing feel out from under the clutch sprocket. wicked noisey. My buck 25 bike
