Gear Ratio
- KZB2 650
Re: Gear Ratio
17 Aug 2018 12:05
Ran 16/41 for a long time but went back to 16/42 when I went with the new chain and sprockets a while back. Tried 17/41 (which is slightly higher than what you have now) once for a trip (to calm the rpms down) and it killed acceleration for me but you have those extra 160cc. (110 now).......I agree with JR wouldn't go any less and if you ever feel the need for some 1/4 mile action Zuk has it right with at least 16/42 or 45.
Once in a while I throw on a 15 tooth front (just bought a new one) which is pretty close to Zuk's 16/45 set up and tear up the streets but always have gone back as its too wild for the highway . Sure comes outta the hole nice though.:woohoo:
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- zukdave
Re: Gear Ratio
17 Aug 2018 15:19
I run the 16-45 for 1/8 mile drag racing it go's through the light's just under the 10,500 rev. limiter.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
The following user(s) said Thank You: KZB2 650
