550 clutch push rod ball size
  • Wozza
  • Wozza's Avatar Topic Author
Re: 550 clutch push rod ball size
03 Sep 2018 18:30 - 03 Sep 2018 18:33
#790276
haha. When i pulled the clutch cover i found scuff marks on it from the preassure plate hitting it in operation
1982 KZ550H1
Last edit: 03 Sep 2018 18:33 by Wozza.
  • TexasKZ
  • TexasKZ's Avatar
03 Sep 2018 20:00
#790286
:pinch: :blink:
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
04 Sep 2018 04:58 - 04 Sep 2018 04:59
#790301
As an option, you can convert your clutch using some of the A Model Parts.
'85 GPz550(ZX550-A2)
Last edit: 04 Sep 2018 04:59 by CoreyClough.
  • martin_csr
  • martin_csr's Avatar
04 Sep 2018 06:14 - 04 Sep 2018 06:16
#790304
CoreyClough wrote: I am so glad the A Model doesn't use this clutch actuator set up.
Do you mean the 550-A1 model? The diagrams are showing both types in the 80-81 clutch diagram, but the 82-83 diagram only shows the newer style found on the 550H. So I'm assuming the A1 has the old style & the 81-on 550As have the newer one. Thanks.
Last edit: 04 Sep 2018 06:16 by martin_csr.
  • loudhvx
  • loudhvx's Avatar
04 Sep 2018 08:41 - 04 Sep 2018 08:45
#790315
Corey means Zx550A1 (84 Gpz550) where the actuator is inside the clutch cover. No sprocket-side actuator or pushrod or ball.
Last edit: 04 Sep 2018 08:45 by loudhvx.
