Bubbles coming from Head/Cylinder Gasket
- zukdave
Re: Bubbles coming from Head/Cylinder Gasket
17 Dec 2017 16:03
Use factory gaskets you can them at a good price from Partzilla.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- k1z947060
17 Dec 2017 16:44 - 17 Dec 2017 16:47
Doesn't look like they carry them any longer. Also - I already order a head and base gasket off eBay - it was the post oil leak service bulletin 4/400-13 gaskets. So hopefully those two should seal it up pretty good.
Trying to think of anything else while I have this thing apart....
It has been blowing some smoke until it's warm. Hard to say if it was burning oil or what.. maybe it was due to this leaky gasket? I want to make sure its done right this time... The rings were replaced about 300 miles ago, and I checked the top rings in the bottom of the cylinder and they were in spec.
1976 KZ400
Last edit: 17 Dec 2017 16:47 by k1z947060.
17 Dec 2017 18:37
I'm not familiar with the 440 but there is a portion of the 750 head gasket where Kawasaki recommends sealer. Point being, look in your manual.
