gpz 550 cams in a kz550 or zr550?
- CoreyClough
- GPz550 Addiction
Re: gpz 550 cams in a kz550 or zr550?
06 Dec 2017 04:15
When I check my cam timing this weekend, I will us the .040" and .050" as the two starting points. I will not be doing this at "zero" valve clearance., but I have in the past, once the clearance was set, I'd install the closest feeler gauge to get the clearance to "zero" and take readings, but is bends the crap out of the feeler gauge. I normally start at .040" as that is what I've used when degreeing my Megacycle Cams. When doing those cams, getting the lobe centers to their recommended 105/108 is all I shoot for in adjusting them,. Oher than makin sure the valve clearances are within spec, and of course piston to valve clearance is good, but once these two are done, it's adjusting for lobe centers.
I offered to check Mark's Cams this weekend as well, but he will not be able to come over. In an e-mail, he seriously thinks his clutch is slipping, but we won't know his "seat of the pants" results until he fixes that, and rechecks for everything else.
Thanks for all the great information added to this thread.
'85 GPz550(ZX550-A2)
- loudhvx
06 Dec 2017 09:57 - 06 Dec 2017 10:19
That's a great post!
My only issue with diagrams like that, below, is that it tends to confuse people.
People may interpret the image as if it is a drawing of looking down the end of a camshaft. Obviously, on a Kz four, all of the lobes will be physically spaced at perfect 90 deg angles from each other.
The other problem with graphics is that we are working in crankshaft degrees, so our cams actually have 720 deg per rotation. It's sometimes easy to lose that in our 360 deg minds, at least for it is.
That diagram shows the lobe separation in crank degrees, but the lobe shape, as it's drawn, implies cam degrees, so there is sort of a conflict of interpretation.
I don't have a better suggestion, as I haven't seen any cam timing diagrams that were instantly self-explanatory.
They tend to look like this, and it's what mine look like, but it's not exactly "speaking" to me.
Actually, mine tend to be more rustic
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 06 Dec 2017 10:19 by loudhvx.
The following user(s) said Thank You: Zaddict
- Daftrusty
06 Dec 2017 14:08
You are correct! I should have labeled that diagram as it only illustrates what LSA’s are and the little triangle between the lobes that illustrates the valve overlap.
But we have completely separate intake and exhaust cams, so it is confusing instead of clarifying like I hoped.
I also started drawing out the cam timing graphs for the different setups and it quickly became less helpful when comparing the three. So I switched to an online calculator as it made for a better numerical visual aid.
Not very helpful
Not very helpful
1990 zr550
kz750e
650/750 6-speed Transmission Swap
kz750e
- CoreyClough
- GPz550 Addiction
06 Dec 2017 16:02
Nice work there!
Are this the theoretical readings, at zero clearance?
- Tyrell Corp
06 Dec 2017 18:01
.please correct me if this is wrong!
I think the ZR550 cams are 248, not 270. They are mild for punchy bottom end and midrange, I think the same grind as the pre gpz z550 series.
Remember the cams work half the speed of the crank, so a tooth out doubles up the error when measured as degrees of crank rotation.
The following user(s) said Thank You: CoreyClough
- Daftrusty
06 Dec 2017 20:47Tyrell Corp wrote: .please correct me if this is wrong!
I had to refer back to the factory service manual and it states that the zr550 duration is 270°.
1990 zr550
kz750e
kz750e
- loudhvx
06 Dec 2017 21:36 - 06 Dec 2017 22:33
Brendan, in the U.S. we have the Zr550B which uses the "two-groove" grind (270 duration), which is the same as the 550D and 550H gpz. In Europe, there is a Zr550A, which has the nicely confusing marketing name of Z550F, that looks very much like a 550H Gpz, but without the front fairing. That bike uses the no-groove standard grind cams (248 duration).
Corey, I believe the published cam timing specs are checked with zero lash and are based on the assumption that the timing marks line up perfectly at TDC. With those parameters, I get very close to the published specs reliably. We know for a fact that the published specs are not exactly correct for the Zx as the sprockets show it to be impossible. But the published specs are only off by a degree or two such that the total difference is about 3 crank deg.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 06 Dec 2017 22:33 by loudhvx.
- CoreyClough
- GPz550 Addiction
07 Dec 2017 06:05 - 07 Dec 2017 06:07
Not to be too critical on this, but my readings will be testing the cam profile of the ZX Cams on a ZX Engine. I don't want to overtake this thread, but in all my GPz Years, I have never needed or wanted, to check cam timing. I will only be taking readings from #4 intake and#4 Exhaust Cam Lobes because they are easy to get to. The valves will be checked and gapped within the recommended settings before taking readings. This information should be useful.
Thoughts?
Thoughts?
Last edit: 07 Dec 2017 06:07 by CoreyClough.
- loudhvx
07 Dec 2017 08:20 - 07 Dec 2017 08:32I think you are doing it the right way for real-world setup on a race bike.CoreyClough wrote: Not to be too critical on this, but my readings will be testing the cam profile of the ZX Cams on a ZX Engine. I don't want to overtake this thread, but in all my GPz Years, I have never needed or wanted, to check cam timing. I will only be taking readings from #4 intake and#4 Exhaust Cam Lobes because they are easy to get to. The valves will be checked and gapped within the recommended settings before taking readings. This information should be useful.
Thoughts?
I assume you find true TDC of the crank with a feeler of some sort on the piston in order to justify a degree wheel to the crank, then use a dial indicator to identify the #4 lobe centers (where the valve is open the most) to set the position of the centers relative to TDC/BDC? That is how it should be done as long as you have slotted sprockets to get the timing precisely where you want it.
Using the sprocket timing marks and cast-in crank pointer to time the engine is a short-cut method to get you close.
And with a lot of figuring, you can get two or three discreet timing options depending on which sprockets you have, but that amplifies the complexity by several times,
I'm doing a different thing. I am trying to see how close the actual cams and sprockets come to the published specs. After measuring several cams of each type (only two Zx, though) I can see the published specs are within about 2 or 3 degrees of what they claim. So if you use the shortcut method of cam timing (the factory service manual method), and everything lines up perfectly (which it never really does), the closest you will come is a couple/few degrees off. Good enough for government work.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 07 Dec 2017 08:32 by loudhvx.
- Zaddict
- Enjoying my Zaddiction!
07 Dec 2017 19:39
man, I'm loving this thread. So much helpful info.
I owe you guys some dyno results but I can tell you already the bike is running super strong. Forget everything I said about the last test ride - I'm 99% sure the problem was that my clutch was slipping. I was even thinking that day that the bike was louder than usual but didn't mention it because I didn't see how that could make sense, but now that I'm thinking about it, it was probably louder because it was revving higher than usual. I've been riding the bike around the city and took it for a short run on the highway yesterday. It's got plenty of power across the full rpm range. Maybe slightly down on the low end (hard to tell), but almost certainly up on the high end.
1990 Zephyr zr550 B1
Wiseco 615cc kit
zx550 cams
SPII ignition system
Kerker stainless steel race exhaust with 1.5" competition baffle
K&N Air Filter...
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
- CoreyClough
- GPz550 Addiction
08 Dec 2017 04:07loudhvx wrote:I think you are doing it the right way for real-world setup on a race bike.CoreyClough wrote: Not to be too critical on this, but my readings will be testing the cam profile of the ZX Cams on a ZX Engine. I don't want to overtake this thread, but in all my GPz Years, I have never needed or wanted, to check cam timing. I will only be taking readings from #4 intake and#4 Exhaust Cam Lobes because they are easy to get to. The valves will be checked and gapped within the recommended settings before taking readings. This information should be useful.
Thoughts?
I don't plan on adjusting cam timing, just taking the readings as the cams are installed now. I do have a piston stop tool, degree wheel, and dial indicator. I'll take the readings, and plug in the numbers. I'll even try it with as close to zero valve clearance as possible. I do have a set of slotted cam gears I could install at a later date, if I wanted to adjust them to a specific timing. For now, if they are close, I'm leaving them where they are.
Glad you rechecked the "seat of the pants" on your set up Mark. We can always set it back to where it was with the other cams if you ever wanted to. :dry:
- CoreyClough
- GPz550 Addiction
09 Dec 2017 22:39 - 09 Dec 2017 22:45
I will have to get these readings next weekend, and as Marcia Brady said, "Something suddenly came up".
Last edit: 09 Dec 2017 22:45 by CoreyClough.
