1982 KZ100 CSR
  • VTEC
  • VTEC's Avatar
Re: 1982 KZ100 CSR
15 Nov 2017 18:01
#774653
I fully understand hydraulics. Don't you think increasing the stud hole ID equally to the oversized stud OD will accomplish the same as external lines? And again, have you ever seen evidence of oversized studs in OEM block and head causing any top end damage?
KZ1000-K2
ZRX1100
XR400R
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: 1982 KZ100 CSR
15 Nov 2017 18:22
#774657
No i have not seen an evidence of oversized studs in OEM block and head causing any top end damage and will not.
But if some little piece of what ever stuck in this little passage (after some head work)and block the oil flow you will notice a
top end damage.
Increasing the stud hole ID equally to the oversized stud OD will do the same as external lines.
But it can be a source for oil leaks between the cylinder block and head.
  • VTEC
  • VTEC's Avatar
Re: 1982 KZ100 CSR
17 Nov 2017 17:02 - 17 Nov 2017 17:37
#774717
The restriction issue would be in the head since the hole IDs are smaller than the block. My calculations, given to me by a mechanical engineer, gives me drilling out the head holes to 11.8mm. This would still be less than the block OD. This means the o-ring mating surface top and bottom would be near equal and would not cause an oil leak (also going to use the 0-ring spring washers used on P bikes). At the same time, as suggested by another member, when drilling the head drill upward and stop after passing the horizontal oil galleys. This will maintain the sealing surface of the top sealing washers.
I know I'm a pain, but really appreciate all the knowledge from you experienced KZ guys.
PS: Thank you, who ever fixed the site page-load issue.
KZ1000-K2
ZRX1100
XR400R
Last edit: 17 Nov 2017 17:37 by VTEC.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: 1982 KZ100 CSR
17 Nov 2017 17:43 - 17 Nov 2017 17:43
#774721
Yea, the site loading times are a lot faster, thumbs up to the admins
Last edit: 17 Nov 2017 17:43 by Scirocco.
  • ajsfirehawk
  • ajsfirehawk's Avatar Topic Author
Re: 1982 KZ100 CSR
18 Nov 2017 17:27
#774777
I received the o-rings, and I have the top end all reassembled. The stockers were malformed so I really did need new ones. All new gaskets and o-rings from the base cylinder up. Monday looks like a full days work so I should be able to get the Dyna coils and plug wires installed with the Wired George mod, the carbs and all the cables back on it.
PS- Apologies for hijacking the thread. 8-)
80 KZ1000 Z1 Classic
83 KZ1100 LTD
18 Z900RS
23 Mach 1
  • VTEC
  • VTEC's Avatar
Re: 1982 KZ100 CSR
18 Nov 2017 18:02
#774781
There's no such thing as good 30 year (or even 10) year old rubber.. I do 10-15 year old rear main seals on a regular basis. Leaking like hell and brittle like hard plastic when I pull them out. And that's under much lower temperatures than an air cooled head.
KZ1000-K2
ZRX1100
XR400R
  • ajsfirehawk
Re: 1982 KZ100 CSR
18 Nov 2017 21:45
#774788
True enough. I was quite surprised their shape was distorted.
83 KZ1100 LTD
18 Z900RS
23 Mach 1
  • ajsfirehawk
Re: 1982 KZ100 CSR
21 Nov 2017 10:59
#774888
Installed the new Dyna coils and spark plug wires. Added the Wired George mod as I had 12.3V on the battery and only 10.1V at the coils. Installed the carbs, addressed a bind in the throttle sleeve and bar end plug. Installed a new speedo cable as the prior one had broken off the tips at the drive end. Blew out the broken tips with compressed air. Installed the exhaust. I should be able to add some fluids, install the tank and fire her up today. I'll repost pics once completed.
83 KZ1100 LTD
18 Z900RS
23 Mach 1
  • ajsfirehawk
Re: 1982 KZ100 CSR
21 Nov 2017 13:50
#774895
Bike fired up second try. I've got what sounds like cam chain noise at low rpm. 1,500 and below. Spin it up to 2,500 rpm and it quiets down. Thoughts as to why this is happening?
83 KZ1100 LTD
18 Z900RS
23 Mach 1
  • TexasKZ
  • TexasKZ's Avatar
  • Away
Re: 1982 KZ100 CSR
21 Nov 2017 14:16
#774896
Carbs out of synch can cause a surprising amount of cam chain noise.
  • ajsfirehawk
Re: 1982 KZ100 CSR
21 Nov 2017 15:34
#774899
Thanks for the feedback TexasKZ. I color tuned and vacuum synced the carbs during rebuilt. I'll recheck. I suspect something wonky is going on with the cam chain tensioner.
83 KZ1100 LTD
18 Z900RS
23 Mach 1
  • ajsfirehawk
Re: 1982 KZ100 CSR
22 Nov 2017 12:31
#774933
No cam chain noise, woohoo! Runs like a deer until I hit 4.5K rpms. Lean according to the plugs and that was my sense of things when I was riding. I'm going back out after lunch and installing 132.5s or 135s. Stockers are 122.5
83 KZ1100 LTD
18 Z900RS
23 Mach 1
