Starter and crank bolt problems 17 Jul 2017 19:27 #767220
  • Shdwdrgn
  • Shdwdrgn's Avatar Topic Author
  • Thank you received: 24
Well it should just thread right in the hole, otherwise you may have some gunk in the threads? I found that a 7/16 x 20 tap fits the threads, and went in the hole very loosely so I was able to just move it around by hand to clean out the old grease. My torque wrench only goes up to 80 so I had to kind of wing it for tightening. I cranked it down as hard as I could while holding everything in place, then I used a regular wrench and a hammer to tap the bolt down a bit more snug. It's not accurate, but it's holding.
The rubber damper is a disk behind the gear, I guess about 3" in diameter? It's mostly flat, but then it curves over into a lip at the outer edge. Looking at the rubber part, you'll see one, two, or three dimples which will tell you what thickness it *should* be. The lip should face towards the block so the flat side of the rubber disk is against the back of the gear. Then there's a copper washer that goes between the gear and the alternator. If all goes well, just holding the pieces together you should see that the gear spins freely in one direction (clockwise) but not the other. When you tighten down that center bolt, you should feel just a slight drag on the gear, but it should still spin pretty easily.
The problem I had was that the copper washer had been placed *behind* the gear, so when the bolt was tightened down the washer got domed out. This bound up everything so the gear did not spin in either direction.
Sorry I didn't grab any pics while I was working on it. Does the description help you any?
1981 KZ1000-JK1
She's a beautiful mess, and I've made her all mine
Starter and crank bolt problems 17 Jul 2017 21:22 #767225
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2609
Starter and crank bolt problems 17 Jul 2017 21:26 #767226
  • Shdwdrgn
Aww come on, where's the fun in using the *right* tool? :)
1981 KZ1000-JK1
Starter and crank bolt problems 18 Jul 2017 07:00 #767236
  • SWest
  • SWest's Avatar
  • 10 22 2014
No eBay APP ID and/or Cert ID defined in Kunena configurationWell then, take this.:lol:
Starter and crank bolt problems 23 Jul 2017 19:50 #767567
  • Shdwdrgn
Jumping back into this thread because I have a new problem. After sitting for most of the week I finally got the carbs adjusted and back on the bike, but when I hit the starter switch I got this grinding sound like gears. It will catch occasionally and I've managed to start the bike up a few more times over the weekend, but finally dug into it today to see if I could figure out the problem...
I ran across some other threads suggesting a similar sound would be heard if the starter clutch was not grabbing. Considering the previous problems, I thought this was a good place to start. When I popped the alternator back off again, I found what I thought was a loose bolt on the back of the clutch. Turns out it was actually a broken bolt. "Ah-HA!" I thought, surely this was my problem! Since the other unit I have has slightly shorter bolts, I swapped all three to maintain the balance, and used a piece of wood to smack the hex wrench and make sure the bolts were all snug. Confirmed there was no damage where the clutch grabs, then reassembled everything and tried again. UGH! Still making the same noises! I just don't see how it was working perfectly last weekend, then after sitting for a few days it suddenly is broken?
So then only other thing I can think of is the starter motor. Perhaps someone can tell me -- is the gear on the starter directly connected to the motor shaft, or is there internal gearing in the starter? If there is internal gearing, is it possible to take apart the starter? I have three starter motors sitting here, however only one of them actually works when power is applied. Another has a dead short in it, and the last is completely dead... BUT there is a good chance that I might be able to swap around internal components if something is broken in my working motor.
And in the off chance that there are NOT any internal gears in the starter motor... what else could it be? I had the timing cover off today and could see that the main crank was only hesitantly turning over, and there is no sign of grinding on the visible starter gears. Considering all the frustration with the engine idle speeds, it would be nice if I could at least get this part fixed.
1981 KZ1000-JK1
Starter and crank bolt problems 23 Jul 2017 21:23 #767571
  • Shdwdrgn
I found some pics of a starter tear-down showing that the gear is actually ground into the motor shaft, so definitely no internal gearing like I was hoping.
I guess that means I'm back to the clutch again. Should I maybe hit the clutch ring surface (on the one-way gear) with some #600 emery cloth? I suppose there could be glazing similar to a disc brake that needs broken up and that surface does have a shiny polished finish to it. All three of the small steel cylinders are moving freely against their springs, and spinning the gear by hand caused them to lock and turn the engine.
1981 KZ1000-JK1
Starter and crank bolt problems 23 Jul 2017 21:33 #767572
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1892
1. is it possible to take apart the starter? Yes you can.
2. is the gear on the starter directly connected to the motor shaft? Yes it is one piece shaft with no internal gearing.
It could be the bearings in the starter are damaged or the starter clutch did not disengage and and revĀ“s
the starter motor out of his limit. .
Have you check the starter clutch internal rollers and springs of any kind of wear?
Have you test that the starter gear turns freely counter clockwise?
Michael
Last edit: by Scirocco.
Starter and crank bolt problems 24 Jul 2017 07:58 #767602
  • Shdwdrgn
By the way, is the starter solenoid supposed to have some sort of built-in delay time to it? I've noticed when I touch the starter switch that the motor will continue to crank for a seemingly random period (up to a couple seconds) after I release the switch. Releasing the clutch and even turning off the key has no affect on this. At first I was thinking this was something meant to smooth out dirty contacts on the starter switch, but then it occurred to me that this was from 1981 and unlikely to contain anything like that.
1981 KZ1000-JK1
Starter and crank bolt problems 24 Jul 2017 17:48 #767635
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2050
No delay. It should should stop right away.
Starter and crank bolt problems 24 Jul 2017 19:35 #767647
  • SWest
  • SWest's Avatar
  • 10 22 2014
The damper may be too thick.
Starter and crank bolt problems 24 Jul 2017 19:38 #767648
  • Shdwdrgn
That's what I was thinking, the solenoid must be sticking then. Erg.
1981 KZ1000-JK1
Starter and crank bolt problems 24 Jul 2017 20:24 #767651
  • Shdwdrgn
@SWest -- This isn't the sound of the engine dragging the starter with it like I originally had. This happens when the engine isn't actually starting and I let go of the starter button. Since the button is dependent on both ignition power and the clutch kill switch (and it keeps trying to start even after I release the clutch and turn off the key), the solenoid is really the only thing that could continue applying power to the starter motor I believe.
As for the damper, it's still working as expected... once I torque the crank bolt I get a light drag in one direction and it locks in the other direction (at least by hand).
1981 KZ1000-JK1
