Low Compression?
  • Dr. Gamma
  • Dr. Gamma's Avatar
Re: Low Compression?
13 Jul 2017 09:37
#766844
Instead of messing around with all this compression gauge stuff. Just do a leak down test on your motor. That way you will know for sure if you have a problem!!!!!
Leak down test will tell you EXACTLY where your problem is. Its the only sure way of checking a motor that you have questions about!!!
1986 RG500G 2 stroke terror.
The following user(s) said Thank You: GPz550D1, Nessism, daveo
  • Nessism
  • Nessism's Avatar
14 Jul 2017 16:45
#766957
How much oil is the engine burning? I wouldn't be concerned in the least with 140 psi unless it's smoking and burning oil.
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
14 Jul 2017 17:00 - 14 Jul 2017 17:07
#766960
Nessism wrote: How much oil is the engine burning? I wouldn't be concerned in the least with 140 psi unless it's smoking and burning oil.
I'm adding a little oil every other day when not riding it, and more every day when I am. It's like the oil fairy siphons it out when nobody is watching.:evil:
Actually, I suspect evaporation is the real culprit...:whistle:
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 14 Jul 2017 17:07 by daveo.
