- Thank you received: 11
Plug wire cap question
- Jussumguy
14 Jun 2017 18:59 #764400
by Jussumguy
Plug wire cap question was created by Jussumguy
Hi I have a 2005 kz 1000p. It is for the most part nice origional condition. It has always had a funky idle, ocasionaly popping out the pipes at different times. Never a constant miss or any thing just random.
I have been all over the carbs, bs 34s. I have them on other bikes I have so nothing new to me.
After reading here I decided to add block off plates on the air injection system and put new 2.2 ohm dyna coils on. I also ordered the plug wires from the same supplier.
The wires came with cheap looking car style ends that require you to put the aluminum nut thingy back on the plug. I decided cut them off and put the nice Bakelite stock ends on. Now I'm thinking maybe the stock ends are resistor and I should have left the wires alone. Did I screw the pooch?
- Jussumguy
14 Jun 2017 19:03 #764402
by Jussumguy
Replied by Jussumguy on topic Plug wire cap question
- Thank you received: 2098
14 Jun 2017 19:06 #764403
by Patton
Replied by Patton on topic Plug wire cap question
Solid wire core plug wires?
Should not use resistor plug wires with resistor plug caps.
- Thank you received: 2749
14 Jun 2017 19:14 #764405
by SWest
Replied by SWest on topic Plug wire cap question
Does the timing light reflect the miss?
- daveo
- Thank you received: 654
14 Jun 2017 20:08 #764406
by daveo
1982 KZ1100-A2
Replied by daveo on topic Plug wire cap question
Just replaced my black solid copper core black wires with red ones shown sitting on the cushion in the photo foreground...
I attach the factory crimped end with rubber boot to the coil terminal, and screw the resistor (or non-resistor) caps on the cut-end depending on what spark plugs are being used. That is, resistor caps for non-resistor plugs, and non-resistor caps for resistor plugs.
I still have the black ones btw. :whistle:
1982 KZ1100-A2
- Jussumguy
14 Jun 2017 20:23 #764407
by Jussumguy
Wow thanks for the fast replys!
I guess my question is, are the stock caps resistor?
I never thought to check with a timing light. Just replaced coils because the stockers have been cooking under the tank for 64,000 miles
If I put non-resistor plugs in it would that make it right or should I crimp the rubber ends back on it?
Once again thanks for the help
- daveo
14 Jun 2017 20:36 #764409
by daveo
The following user(s) said Thank You: GPz550D1, Jussumguy
14 Jun 2017 20:40 #764410
by SWest
The reason I asked the problem may lie elsewhere.
- Jussumguy
14 Jun 2017 21:03 #764411
by Jussumguy
I have set the valves,
Compression is 150,160,150,170
Stock jets in the carbs--at sea level, generaly hot and dry here unless it's cold and wet. Went up one size on pilots but it was way rich. Float level are at spec. Stock air cleaner(foam)
And kerker header with street baffle. Starts great and hauls ass and sounds wonderful on the pipe. Just idle is all floopy floppy
14 Jun 2017 21:18 #764412
by SWest
Carbs synced and how's the spark advance. I'll look at the timing light to see if it's a electrical miss but if misfiring due to carb malfunction that could be misleading.
- Jussumguy
14 Jun 2017 22:22 #764416
by Jussumguy
Oh sorry Steve
I thought I posted a response, carbs are synced. Being it's a 2005 with electronic ignition I didn't think it had a mechanical advance. I took the cover off and everything is shiny and new looking but the shaft was a little gummy feeling so I sprayed it with wd40. It's a little free er now .
I'll take it for a ride tomorrow and see how it feels. Thanks for the help!
15 Jun 2017 05:29 #764426
by SWest
WD ios only a temp. fix. I use grease and oil it once in a while.
