Valve Adjustment on KZ1000 Police. Two Questions.
- VTEC
Re: Valve Adjustment on KZ1000 Police. Two Questions.
23 Apr 2017 17:32
Remember, on the J engine, you have to remove the chain tensioner plug and shaft before re-installing the cam cover.
KZ1000-K2
ZRX1100
XR400R
ZRX1100
XR400R
The following user(s) said Thank You: bl_francis
- bl_francis
30 Apr 2017 11:17
Thanks. That is very helpful.
Let me see if I understand what you're saying…
I pulled each shim and measured their thicknesses on the ones that are too tight. Then I subtracted 0.15 and also 0.05 from them. That gave me an idea of what the thickness of the shim should be between the max. and min.
So existing shim was 2.50 mm. I subtracted 0.15 and got 2.35. The I subtracted 0.05 and got 2.45. I thought that if I got a shim between 2.35 and 2.45 that I'd be good to go.
But, what you're saying is that it could be WAY too tight even with the existing shim in it. I should put a really thin one in each and go from there. That is a pain but it does make sense.
1987 KZ1000 Police
- bl_francis
30 Apr 2017 11:18
1987 KZ1000 Police
- bl_francis
30 Apr 2017 11:20
OK I will have to check the manual to see that both of those are.
1987 KZ1000 Police
- ThatGPzGuy
01 May 2017 05:44 - 01 May 2017 15:24bl_francis wrote: Thanks. That is very helpful.
Yes. You have to have a gap to measure which is why you go with the thinnest shim. It's a pain but once you get good with the batwing it's not really that bad. Plus you only need to do it on the valves that don't have any clearance.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Last edit: 01 May 2017 15:24 by ThatGPzGuy.
The following user(s) said Thank You: GPz550D1, bl_francis
- gvsu141
01 May 2017 07:47 - 01 May 2017 07:48
I just went through the same thing on my '82 LTD - Except 6 of the 8 valves were so tight that I couldn't get my smallest feeler gauge in there (.04mm)
A good rule to follow is if you can spin the bucket freely with your finger, go 2 sizes smaller than what's in there now. So if you have a 250, go with a 240. I ordered the new shims from Z1E, and it put me right on the money for all my valves.
If it is so tight that you can't spin the bucket, I like to do what GPzGuy mentioned.
2001 ZRX 1200
1973 z1 900
1975/73 z1 Turbo Dragbike
1982 GPZ550 - 62 Miles
1973 z1 900
Last edit: 01 May 2017 07:48 by gvsu141.
