Best bang for buck mods for 81 KZ550?
- Wildman1024
11 Mar 2017 13:13
My 550 already runs pretty good. Just wondering whats the best bang for the buck mods to really make as much power as possible with this bike.
78 Kawasaki KZ650B
1973 Yamaha RD350
1983 Honda CB1100F
1973 Yamaha RD350
1983 Honda CB1100F
- Wildman1024
Re: Best bang for buck mods for 81 KZ550?
11 Mar 2017 14:38
78 Kawasaki KZ650B
1973 Yamaha RD350
1983 Honda CB1100F
1973 Yamaha RD350
1983 Honda CB1100F
11 Mar 2017 16:01
1981 GPz cams would be a better value.
- Wildman1024
11 Mar 2017 16:34Nessism wrote: 1981 GPz cams would be a better value.
If I can find some.
78 Kawasaki KZ650B
1973 Yamaha RD350
1983 Honda CB1100F
1973 Yamaha RD350
1983 Honda CB1100F
11 Mar 2017 16:53Wildman1024 wrote:Nessism wrote: 1981 GPz cams would be a better value.
If I can find some.
Ebay. Less than $100 shipped for a set.
- Wildman1024
11 Mar 2017 17:03Nessism wrote:Wildman1024 wrote:Nessism wrote: 1981 GPz cams would be a better value.
If I can find some.
Do you have a link cause I must have missed them.
78 Kawasaki KZ650B
1973 Yamaha RD350
1983 Honda CB1100F
1973 Yamaha RD350
1983 Honda CB1100F
- loudhvx
11 Mar 2017 20:29 - 11 Mar 2017 20:37
If you start making more power, you will want a gpz oil pan so you can add an oil cooler.
Best bang for the buck using bolt-on parts, "to really make as much power as possible with this bike", would probably be a used gpz motor, though. A used 82 to 85 gpz motor will allow you to use the bigger CV carbs, and of course would already come with the cams, pistons, and oil cooler, (or at least the place to hook up the cooler) you would want. That's if you can find a deal on a motor. $200 tops for a decent one.
I would first make sure your current motor is tuned properly, and ride it, and just wait for the right motor to come your way. I've ended up getting entire gpz's for next to nothing, but just had to be patient.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 11 Mar 2017 20:37 by loudhvx.
- Nerdy
11 Mar 2017 20:31Nessism wrote: 1981 GPz cams would be a better value.
IIRC the KZ heads aren't quite the same as the GPz heads. If that's the case, there would be some improvement but he wouldn't get the full benefit of the GPz cams without additional head work.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
- Wildman1024
12 Mar 2017 01:28loudhvx wrote: If you start making more power, you will want a gpz oil pan so you can add an oil cooler.
Didn't the later year gpz550's make like 65hp? Does that motor still bolt right in?
78 Kawasaki KZ650B
1973 Yamaha RD350
1983 Honda CB1100F
1973 Yamaha RD350
1983 Honda CB1100F
12 Mar 2017 05:27Nerdy wrote:Nessism wrote: 1981 GPz cams would be a better value.
According to the OEM parts fishe the head is the same in 1981, thus the reason for my suggestion about the cams. Personally, I'd just leave the KZ engine alone though. We are talking about a 35 year old motorcycle that is running well. Just ride and save for a faster bike if that's what one wants. This approach would be different if the engine was in need of work though.
12 Mar 2017 05:28Wildman1024 wrote:loudhvx wrote: Didn't the later year gpz550's make like 65hp? Does that motor still bolt right in?
Yes; 65 hp. See link below. Ed
www.motorcyclespecs.co.za/model/kawasaki/kawasaki_gpz550_83.htm
- loudhvx
12 Mar 2017 08:39 - 12 Mar 2017 08:40
I never noticed any difference between the gpz head and a kz head, but maybe there is some porting done (that was the rumor according to magazine articles, but I don't give that much weight considering how much else they get wrong). Obviously, since the gpz and kz use the same carbs, the inlet of the intake ports have to be the same. Maybe Kawasaki ported the heads on the bike that was lent out for reviews (the kz came out 1 year before the gpz, so magazines would have been able to inspect/compare the gpz test bike against a showroom kz).
The Zx 550 motor uses the same Kz550D (81 gpz) cases. The motor mounts are different on the Zx. It has more rubber mounting, but I think the motor is compatible to a Kz frame. Either way, the 82/83 motor bolts in. That's what I have in one of my 81's.
But I am also of the opinion you should keep the bike with the good motor in it. Once you change the motor, you will want the gpz brakes/wheels.
If your bike is running perfectly, I (like Nessism said) would leave it in tact. Just look for a hashed out project bike to play with. There are always plenty of bobbed/chopped incomplete bikes on craigslist for cheap. It would be great to see a chopped up Ltd become a decent gpz replica.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 12 Mar 2017 08:40 by loudhvx.
