- Thank you received: 1
80 KZ550 LTD caliper piston seal size?
- nikkievix
- you know what the fox says...
28 Feb 2017 03:36 #755416
by nikkievix
80 KZ550 LTD caliper piston seal size? was created by nikkievix
allo..i got my bikes caliper apart..unfortunatly the dust boot and piston seal came out in pieces, the piston and the bore cleaned up nice and smooth. however, i'm looking to source the replacment seals localy and in need of the seal sizes and thicknesses since i lack the fancy tools to messure those areas. looking to find a dust boot/seal for a car in the same size.
- Thank you received: 2823
28 Feb 2017 05:05 #755421
by Nessism
Replied by Nessism on topic 80 KZ550 LTD caliper piston seal size?
OEM Kawasaki parts. Order from dealership or one of the dozens of sources that sell on line such as Partzilla.
www.partzilla.com/parts/search/Kawasaki/...+C1-C2%29/parts.html
43049-1098 PACKING,PISTON SEAL
49006-1043 DUST SEAL,PISTON
If the piston has metal pits it must be replaced as well.
