KZ1100 Sprecra questions
  • Kitten Tooth
  • Kitten Tooth's Avatar Topic Author
Re: KZ1100 Sprecra questions
16 Feb 2017 17:14
#754380
on the main bearing stiffener plates, maybe there aren't main bearing caps in the J motor and the case halves are the main bearing caps basically?
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • Kitten Tooth
16 Feb 2017 17:24
#754381
would a GM distributor from a 2.5 four cylinder work? I notice that alot of the aftermarket distributors say they are only capable of so much engine speed (like 8000 RPM) I suppose I could just try out my design and see what happens. It'll all be junkyard parts anyways.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • zed1015
  • zed1015's Avatar
17 Feb 2017 00:11 - 17 Feb 2017 00:13
#754391
It is the centre main bearings that have the cap which ties the crank to the upper case.
It is that, that needs machining flat and a plate fitting.
Easy to make your own from 8 or 10mm steel plate .
The ( Bill Hahn ) dizzy ignition on the drag bike is built from GM distributor parts, they run at half speed so won't see much above 5500rpm.
Spacer plate goes under the block. Won't be needed if you get the correct forged turbo pistons and the way you are talking of going I wouldn't risk using the stock cast ones.
Unless you are going big block, you don't really need bigger valves on a turbo as it's force fed especially on the inlet.
Exhaust side needs a little help so 1mm bigger there will be fine for your motor.
Same goes for porting. no need to go big. Just blending the inlets and opening the exhaust.
Last edit: 17 Feb 2017 00:13 by zed1015.
  • Kitten Tooth
18 Feb 2017 07:28
#754474
The pistons i found are Wiseco 1170 forged. But the compression ratio is 10.25:1 which i thought was a little high. For the ignition, im looking at old tractor magnetos right now.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • Kitten Tooth
18 Feb 2017 08:01
#754479
No eBay APP ID and/or Cert ID defined in Kunena configurationFound a good looking ignition setup for a suzuki samurai.
I think I got all the engine stuff figured out, now im looking at the frame. Do I need to have a jig to start changing the tubing within the frame? My thought was just to saw the rear most of the frame off and keep the bit that holds the motor. Then weld in my own box steel rear end. I wouldn't mind changing the tubing just above the carburetors to give me alittle more room for the turbo and plenum. Maybe I need to move this question to the chassis area of the forum?
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • Kitten Tooth
18 Feb 2017 08:58
#754484
Figured it out. ill be making my own jig and starting from scratch
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • Puffin
  • Puffin's Avatar
Re: KZ1100 Sprectra questions
19 Feb 2017 12:20
#754576
Looks like you did good (y) Spectras have a good solid motor. For piston try MTC allthough i believe they dropped the 1170 low comp from the the list. Try Joe at Pit stop performance
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
The following user(s) said Thank You: Hoover
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
19 Feb 2017 16:48 - 20 Feb 2017 06:02
#754601
KZ1100 Spectra :blink:
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 20 Feb 2017 06:02 by daveo.
  • Kitten Tooth
20 Feb 2017 07:33
#754641
The title says KZ1100 D
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • Kitten Tooth
20 Feb 2017 07:34
#754642
Oooohhhh its Spectre lol
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • loudhvx
  • loudhvx's Avatar
20 Feb 2017 08:19
#754648
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
20 Feb 2017 08:57
#754651
:laugh: :laugh: :laugh: :woohoo:
