Shift rod problem !
  • rrsmsw9999
  • rrsmsw9999's Avatar
Re: Shift rod problem !
07 Nov 2016 08:57
#747491
You can pull the clutch push rod out all ya want, not the shift rod that hold the shift forks. Maybe I assumed he was talking about the shift rod and not the clutch push rod. The ball bearing in only supposed to come out the clutch side so maybe this is what he means and is in a better position than I previously though. The clutch push rod can just be cleaned and put back in. Hoping that's his situation.
R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
The following user(s) said Thank You: KZB2 650
  • KZB2 650
  • KZB2 650's Avatar
07 Nov 2016 15:58
#747514
Are you serious .... and 100% sure..... you mean to tell me I've been wondering and worrying about this for half of my life for nothing. :blush: :blush: :blush:
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • SWest
  • SWest's Avatar
  • 10 22 2014
07 Nov 2016 16:33
#747517
Pic of what you are talking about?
  • KZB2 650
  • KZB2 650's Avatar
08 Nov 2016 10:39 - 08 Nov 2016 10:42
#747568
What I'm talking about is #12 clutch push rod (if my first adding file works) :dry: ......
Attachment 27438ce98f21fb9fbf3b75b0017466acd96b9f5b.png not found
Guess it worked..... hoping the original poster is as lucky.
1978 KZ650 b-2
Last edit: 08 Nov 2016 10:42 by KZB2 650.
  • rrsmsw9999
08 Nov 2016 14:20
#747584
Yep 12 can be taken out and services from Th heart side. That part does not hold shift forks. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
