400 conversion to 440
- Garrettporter
23 Oct 2016 15:05
Hey riders. Ive got a build on my hands. I bought a bone stock 79 ltd. im gearing it lower to have speed with less rpm. Im wondering if i can put a 440 top end (pistons cylinders and valvetrain) onto my 400. Will it simply bolt up together
- Nebr_Rex
Re: 400 conversion to 440
23 Oct 2016 18:18
How about an introduction of you and your bone stock bike.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Nerdy
23 Oct 2016 18:54Garrettporter wrote: Hey riders. Ive got a build on my hands. I bought a bone stock 79 ltd. im gearing it lower to have speed with less rpm. Im wondering if i can put a 440 top end (pistons cylinders and valvetrain) onto my 400. Will it simply bolt up together
1) Welcome aboard!
2) Respectfully, that is not "bone stock". The exhaust is an aftermarket replacement, and from the look of the headpipes your engine is running very lean and therefore a) hot and b) down on power. Before you start thinking about a conversion to 440cc I recommend you get the 400 running properly first.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
23 Oct 2016 20:54
Good advice as always here. Get the bike running properly before assessing the need for more mods. Those header pipes are running scary hot so figuring out why would be high on the list of things to do.
- 750 R1
23 Oct 2016 22:53
Lowering drive ratio = higher gearing = lower revs for the same speed....
24 Oct 2016 05:12 - 25 Oct 2016 03:48He said he has a build on his hands, so the photo is probably after he's already made some changes.Respectfully, that is not "bone stock".
Last edit: 25 Oct 2016 03:48 by martin_csr.
- Garrettporter
24 Oct 2016 05:46
I am running lean. That's because the carbs have aftermarket needles and the floats need readjustment for them to fine tune them. Ill have to look into the valve twist on them. So thank you for that. And ive included a pick of the bone stock before i made changes. The pipes are stock. The baffle pipe was completely removed and left cyl header moved to rest with the right. Its geting full exhaust this winter, raked and a springer. Any more advice is always helpful. Thanks
24 Oct 2016 05:55
I am pretty sure that the 400 uses a roller cam chain and the 440 uses a hyvo chain, which means swapping the crank. I have read that the 440 liners are too big to fit into the 400 crankcase without modifying the crankcase. Not a drop in deal.
As stated above, those stubby pipes and the lack of the factory air box setup are robbing the engine of much of its power, and the dangerously lean condition will do serious damage to the engine.
24 Oct 2016 05:57
I am pretty sure that cute blonde was not factory equipment :whistle:
- Garrettporter
24 Oct 2016 10:14
The pipes do need to be longer. Do you think that would cause part of the heat problem at the headers? And it does have the air box. I hate that thing lol.
24 Oct 2016 10:44
I'm confused. Did you chop off the pipes right where they cross so they are just about 6 inches long and then dump straight down?
- Garrettporter
24 Oct 2016 10:50
No i took the bugal looking rear part of the exhaust off so the pipes are ending under the bike about where the front of the seat is
