Loss of power when passing
- ahot1968
17 Oct 2016 10:26 - 17 Oct 2016 10:26
I have a 82 550 LTD Bike runs normal at startup and driving but when at higher speeds like 40 or more and I give it a lot of throttle to pass it bogs a severe loss of power and I am not sure why any suggestions
Last edit: 17 Oct 2016 10:26 by ahot1968. Reason: Forgot to mention bike type
- JoHNY
Re: Loss of power when passing
17 Oct 2016 12:55
Check the AFR. Has it got an after market pipe, pods etc?
Kawasaki Z750P7 Spectre, Triumph Daytona 955i, Honda CBR1000FN
- ahot1968
- ahot1968
17 Oct 2016 13:55
Does anyone have any thoughts of what I might try to to start trouble shooting this?
17 Oct 2016 16:42 - 18 Oct 2016 05:15
I would test the battery to make sure it's good.
High beam load test -->> charge the battery w a motorcycle smart charger-->> 12.6+ VDC;
Ign switch on & headlight high beam on (engine off) -->> a good battery will drop to about 12.2 VDC.
If it drops below 12 VDC, the battery may need replacing; if it drops below 11 VDC, the battery is probably shot.
I have a Scorpion AGM from batterystuff.com and use a Ctek US 0.8 smart charger & VC97 digital multimeter.
If the battery passes the load test, ride the bike at highway speeds, then stop & feel the coils; they should be warm, not hot. press hard with your fingers. don't get burned by the valve cover. practice touching them when the engine is cold. You can also check them for cracks or damage. A coil can pass the resistance checks outlined in the manual but still be bad under load.
Also, check or redo the spark plug wire connections at all points. unscrew the ribbed compression boots at the coils to redo those connections. If the wires have the crusty oxidation, nip off the ends a tad. Or go ahead & install new spark plug wires & caps. Check & lubricate the timing advancer. operate it by hand to make sure it snaps back.
Also, make sure the fuel tank petcock is functioning normally.
Last edit: 18 Oct 2016 05:15 by martin_csr.
The following user(s) said Thank You: ahot1968
- ahot1968
17 Oct 2016 17:18
I will check the coils and petcock and update I know the Battery and charging system to good and functional. The coils and wires check out with a meter but I have not checked them physically during/after use.
18 Oct 2016 05:09 - 18 Oct 2016 05:36
How do you know the battery is good? many a rider has assumed the battery was not the problem.
not trying to be an azz, just want to make sure it isn't something simple.
If not done so, load test the battery & check it with a digital multimeter. One time my bike started running poorly at speed, then quit. It would restart & run at low speeds fine: the electrolyte had gotten low. doh. About a year later, same running problem; the electrolyte level was fine, but the battery failed the tests. I replaced it with a Scorpion AGM & am very pleased with that battery. It tested 12.79 VDC straight out of the box. I went ahead & put in on the smart charger for curiosity's sake, and it cycled thru the settings quickly.
When originally getting the bike road ready, there was an intermittent firing problem. After checking & setting everything as per the factory service manual, the problem turned out to be poor spark plug connections. cleaned them up, problem solved. Some time after that, the bike was running funny at speed, it was kind of subtle. The problem turned out to be the coils which were getting very hot to the touch, even though they passed the resistance checks. I installed new green Dyna 3.0 ohm coils & spark plug wire set from Z1Enterprises.com. The grey 2.2 ohm are supposed to be a better match for the stock electronic ignition, but I got the green ones in case I ever needed to get the Dyna S.
Another time my bike started running terrible. The petcock diaphragm failed, evidenced by fuel spraying out of it. doh.
Last edit: 18 Oct 2016 05:36 by martin_csr.
18 Oct 2016 06:56
Did the bike sit for an extended period without the engine being run? If so, the carbs may be dirty from fuel goo. I had this happen many years ago and the symptoms were similar to those you describe. After cleaning the carbs the engine ran great. Ed
18 Oct 2016 07:14
What's measured voltage across battery posts at 4000 rpm?
- ahot1968
18 Oct 2016 08:17
I have 13.6 avg. at 4000 RPM I have been running the bike daily and one day last week the loss of power happened I pulled the carbs and cleaned them out with carb cleanner took out the pilot jet but did not completely disassemble the carbs
- Z1Driver
- love the smell of triple smoke
18 Oct 2016 12:18 - 18 Oct 2016 12:19
what kind of RPM's and gear are you in when you decide to pass? Is it a stumble or the bike simply will not go?
Blue 1975 Z1B
Red 2009 Concours 14
Last edit: 18 Oct 2016 12:19 by Z1Driver.
19 Oct 2016 05:04 - 19 Oct 2016 05:19That seems low. shouldn't it be about 14.5 VDC? did you do a load test?ahot1968 wrote: I have 13.6 avg. at 4000 RPM I have been running the bike daily and one day last week the loss of power happened I pulled the carbs and cleaned them out with carb cleanner took out the pilot jet but did not completely disassemble the carbs
Last edit: 19 Oct 2016 05:19 by martin_csr.
