What size Piston kit to run with Mr Turbo kit 13 May 2017 07:27 #761873
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1967
I was just thinking about your cover.
If you are going to use stock foot pegs and brake pedal as shown in the old picture of my bike you should look into widening your brake pedal. THe MTC cover will keep your foot from being able to fit over the brake pedal correctly. I added to my pedals width by welding on a half of a pad I cut off another extra pedal. Since then I have gone to rear sets made by Les Holt at PDM which you can see in the picture I posted at the beginning of your thread. Now would be the time to do this as fishing for the rear brake while on boost is to late
Dave B) B) B)
What size Piston kit to run with Mr Turbo kit 13 May 2017 12:27 #761881
  • jumbulias
  • jumbulias's Avatar Topic Author
  • Thank you received: 7
Thanks for the info. Your bike is very nice.
What size Piston kit to run with Mr Turbo kit 20 May 2017 16:02 #762326
  • jumbulias
Does anyone have torque specs for dynamo rotor bolt. Factory manual says 51-54 foot lbs. It has to be wrong I have broke two bolts off in crank but was able to get them out.
What size Piston kit to run with Mr Turbo kit 20 May 2017 18:05 #762337
  • jumbulias
Found it!! The 1977 specs are 16.5 - 19.5 FT LBS. Thanks Patton
What size Piston kit to run with Mr Turbo kit 21 May 2017 16:06 #762410
  • jumbulias
Camshafts have been Degreed . What a Pain. Set at 108/112
What size Piston kit to run with Mr Turbo kit 28 May 2017 16:51 #762981
  • jumbulias
Got a little bit done today!!!!!!!!!!!
What size Piston kit to run with Mr Turbo kit 28 May 2017 16:52 #762982
  • jumbulias
What size Piston kit to run with Mr Turbo kit 28 May 2017 17:02 #762983
  • jumbulias
Think the banana pipe goes this way.
What size Piston kit to run with Mr Turbo kit 28 May 2017 17:22 #762984
  • Moderator
Very Nice !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
What size Piston kit to run with Mr Turbo kit 29 May 2017 13:49 #763038
  • jumbulias
Clutch Cover buffed out pretty nice. Used Menzerna buffing compound, It is the best by far!!
What size Piston kit to run with Mr Turbo kit 19 Aug 2017 11:47 #769250
  • jumbulias
Finally found a swingarm Looks nice with 180 tire.
What size Piston kit to run with Mr Turbo kit 04 Sep 2017 16:12 #770339
  • jumbulias
Off work this week Hope to get alot done. Here are some pics. Electronic Tach , Boost Gauge , etc.
