Wire coverings
  • mackinnon0909
  • mackinnon0909's Avatar Topic Author
Wire coverings
31 May 2016 07:44
#729328
Just wondering what you guys use for wire coverings. All the wiring on my 78 kz659sr is wrapped in electrical tape and is a royal pain to work on when something stops working (which is almost every other ride on the old girl).
  • TexasKZ
  • TexasKZ's Avatar
Re: Wire coverings
31 May 2016 07:57
#729331
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: Wire coverings
31 May 2016 08:21
#729337
IIRC I used 3:1 heat shrink from McMaster Carr on a Z1B I was restoring. They sell different ratios, you have to measure the connector if you're not removing it from the harness. There's also Vintage Connections, they sell vintage Japanese electrical parts.
Here's the shrink tubing on the handlebar loom
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • loudhvx
  • loudhvx's Avatar
Re: Wire coverings
31 May 2016 09:15 - 31 May 2016 09:18
#729342
No eBay APP ID and/or Cert ID defined in Kunena configurationUse what the factory used. Non-adhesive electrical tape. That plus a couple small pieces of sticky electrical tape will hold it all in place. It unwraps easy, and you can make a change and re-wrap with the same piece, if you don't have to go too far with the changes.
(oops, didn't see TexasKz's link)
Last edit: 31 May 2016 09:18 by loudhvx.
Re: Wire coverings
31 May 2016 09:39 - 31 May 2016 09:40
#729349
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
  • martin_csr
  • martin_csr's Avatar
Re: Wire coverings
31 May 2016 12:12 - 31 May 2016 12:12
#729370
CycleTerminal.com has a pretty good selection of wiring products for motorcycles.
Wiring Harness Sleeve Tubing, Sheathing Loom
Motorcycle Harness Connector covers handy for the reg-rec connector as it can get dirty from the rear wheel on some models.
ECT 005 open barrel crimper & ET120/123 terminal pin extractor tools
Last edit: 31 May 2016 12:12 by martin_csr.
  • Ed_in_Miami
  • Ed_in_Miami's Avatar
Re: Wire coverings
19 Jan 2017 12:44
#752497
Great stuff!
Bumpy!
This is my build:
kzrider.com/forum/11-projects/600312-ano...rtment-build?start=0
There are many more like it, but this one is mine... news to come!
  • Nessism
  • Nessism's Avatar
Re: Wire coverings
19 Jan 2017 14:39
#752502
That non adhesive tape is often denoted Elliot Tape. EE201 is the high temp type which works great on bike harnesses. I use 3M electrical tape to hold it in place. That silicone tape Ed recommends is fine as well but Kawasaki just used electrical tape.
