No power under load
  • missionkz
  • missionkz's Avatar
Re: No power under load
26 Apr 2016 15:01
#723120
Mostly no but a weak coil fires a spark plug even worse under high engine loads.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • charleylabri
  • charleylabri's Avatar Topic Author
09 May 2016 07:25
#725309
joshkamp1988 wrote: try pulling your plug wires one at a time and see if cylinder 4 has any affect when you pull it. If no affect when you pull cyl 4 switch cyl 4's plug wire with cyl. 1 's plug wire. If the problem jumps to cyl 1 then it's most likely electrical related if not it's most likely something mechanical.
Josh takes the bacon here.
This weekend I pulled the plug wires on the inner plugs while running and nothing happened. Tested the LH drivers coil (should be 3-3.5 ohms between poles) and it was totally dead. RH coil tested good. Its got the green 3 ohm dyna coils.
Ordered a new set from Z1 this morning.
Thanks all!
  • missionkz
09 May 2016 09:39
#725336
Ha ha... Over the last few days, I think everyone here mentioned your coils!!
Bruce
1977 KZ1000A1
