reuse a bottom oil ring???
- pete greek1
Re: reuse a bottom oil ring???
01 Feb 2016 08:21
28.89 from Z1 enterprize for the set
www.google.com/url?sa=t&rct=j&q=&esrc=s&...L6cqeLr4ZIUD3zMbil8A
Pete
Pete
- daveo
01 Feb 2016 19:32
See:
cafebrat wrote: I honed the cylinders, not bored. Everything would have gone together pretty easy if that one ring didn't roll over.
Swest, my model calls for different rings than every other model( part# 13008-5055). I can only find them direct from Kawasaki
See:
1982 KZ1100-A2/1170 sleeper 😀
- cafebrat
02 Feb 2016 03:59
Thanks pete and dave. The only ring set i found on ebay was much more expensive. And ill have to bookmark z1 enterprise for if i ever need another. I searched for hours trying to find those 13008-5055 rings and only found three...parts warehouse ( orders from kawi) kawasaki directly, and one overpriced set on ebay. Guess ill Have to seach better next time to save the $$
83 Kawasaki Kz1100 LTD
81 Honda cm400
72 Suzuki T500 Titan** 2-stroke
81 Honda cm400
- daveo
02 Feb 2016 04:51
Regarding:
The seller may be willing to consider an offer, but one never knows unless asked...
cafebrat wrote: Thanks pete and dave. The only ring set i found on ebay was much more expensive. And ill have to bookmark z1 enterprise for if i ever need another. I searched for hours trying to find those 13008-5055 rings and only found three...parts warehouse ( orders from kawi) kawasaki directly, and one overpriced set on ebay. Guess ill Have to seach better next time to save the $$
Regarding:
- kaw-a-holic
02 Feb 2016 09:51cafebrat wrote: Hey guys, i went to put my cylinders on my pistons today and fucked up one of my very bottom oil rings. I still have all eight identical rings that came out. However i dont know which cylinders they each came from, and i know a few cylinders were having blowby and burning some oil. Would it be a bad idea to reuse just one old bottom ring?? Itll cost me $67 (shipping included) to get a new complete ring set for one piston. Talk about an expensive mistake. Just looking for your opinions if you would just swap it out an not worry about it. Thanks in advance.
I believe I have a partial set for 1015 from my 77 KZ1000a1. I will check for you when I get home.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- Brady 154
Re: Re:reuse a bottom oil ring???
02 Feb 2016 18:11
That has happened to me on modern bikes. I did reuse an old oil ring and had no issues.
1976 KZ900 LTD, resto-mod
-1075 Piston Kit
-PSP 3X Cams (degreed to 106)
-Mikuni RS34 Carbs
-Pod Air Filters
-Dyna S Coils and Ignition
-Race Tech Valve Cartridge Emulators up Front
-Ohlins Shocks out Back
-1075 Piston Kit
-Mikuni RS34 Carbs
-Pod Air Filters
