How much Power?
  • rrsmsw9999
  • rrsmsw9999's Avatar
Re: How much Power?
19 Jan 2016 19:00
#707336
There are things you can do to diminish the buzz. I had a 550 in early 90s that was an LTD and it was not buzzy. I can't say how buzzy the 550A is as I haven't had any long rides on the one the found in Nov. I will say the 650 I had was smooth as silk at all speeds, including 100+. I am expecting the same. With a solid mount engine it is more common to come upon a harmonic disturbance at a specific rpm than true vibes. The pegs can be rubber insulated and different grips will improve bar buzz. You could also add bar end weight in many ways. The avatar you have looks like a stock bike. It goes without saying that wheel balance, proper fastener torque and assembly methods can contribute to vibrations. If the vibes are constant and increase with rpm only I would say you have a tire or chassis issue. if it is high or specific rpm you have a harmonic disturbance that probably has to be tolerated. Get out of that rpm range by shifting or adjusting engine speed. Good luck. I will have mine out for longer rides as soon as possible. :woohoo:
R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
  • loudhvx
  • loudhvx's Avatar
Re: How much Power?
20 Jan 2016 10:04 - 20 Jan 2016 10:08
#707383
For some reason the standard was geared to 16/40 while the gpz's are 16/38. I think they were trying to get a little more acceleration on the standard. From what I've experienced, the standard tends to run out of RPM before it runs out of acceleration, as does the gpz, so you would probably do fine to go 17/40 or 16/38. Those combinations turn out almost exactly the same, and either works fine. 16/40 is a bit buzzy at highway speed. The difference is about 5mph at 5000 rpm.
Last edit: 20 Jan 2016 10:08 by loudhvx.
  • zukdave
  • zukdave's Avatar
Re: How much Power?
20 Jan 2016 16:02
#707439
The KZ motor's simply like RPM's I've seen my motor bump
the rev limiter set at 12,500 in third gear with 16-45 gearing
with stock cams.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
