2-4 crossover style exhaust...
  • PDXDave
  • PDXDave's Avatar Topic Author
04 Nov 2015 07:05 - 04 Nov 2015 07:32
#697180
Anyone here have any experience with a 4-2 cross over type system?
I'm curious about the sound and performance characteristics compared to a 4-1
Last edit: 04 Nov 2015 07:32 by PDXDave.
  • martin_csr
  • martin_csr's Avatar
Re: 2-4 crossover style exhaust...
04 Nov 2015 07:19 - 04 Nov 2015 10:28
#697184
I guess you meant 4-2?
Last edit: 04 Nov 2015 10:28 by martin_csr.
  • PDXDave
04 Nov 2015 07:32 - 04 Nov 2015 07:42
#697185
My bad...
A 4 with 2 mufflers with cylinders 1 and 4 merging into one muffler and cylinders 2 and 3 merging into another.
It's the correct system on a Goose build and I have one coming from Japan, but I was just curious if anyone had any first hand experience with this configuration.
japan.webike.net/products/1523195.html
Last edit: 04 Nov 2015 07:42 by PDXDave.
The following user(s) said Thank You: Dach Savage
  • missionkz
  • missionkz's Avatar
04 Nov 2015 12:16
#697222
If a factory system, as found on the 77' KZ 1000.... It will make max power and be amazingly quiet! That stock system was a semi-marvel of engeering.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
The following user(s) said Thank You: old_kaw
04 Nov 2015 12:30
#697225
Some KZ650 models came with 4>2 cross-over exhaust system. They were rated as having 2hp less than the normal 4>2 system. Ed
  • bountyhunter
  • bountyhunter's Avatar
04 Nov 2015 14:01
#697237
PDXDave wrote: Anyone here have any experience with a 4-2 cross over type system?
Do you mean a 4-2 with a crossover pipe ahead of the mufflers?
If so:
A good 4-1 system will make more HP in the peak power range but probably have a little less power at the low RPM range.
Systems with a crossover pipe generally make more low RPM power which is why stock systems use them.
04 Nov 2015 14:16 - 04 Nov 2015 14:16
#697241
I believe he meant a system where the pipes cross like the KZ650-SR shown below. Ed
Attachment 00003-5.jpg not found
Last edit: 04 Nov 2015 14:16 by 650ed.
  • Nebr_Rex
  • Nebr_Rex's Avatar
04 Nov 2015 16:13
#697269
I needed no jetting changes going from a Mac 4/1 to a SR system with the crossover plugged.
And that was on a 750/4.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • jenkrider
  • jenkrider's Avatar
15 Nov 2015 10:08
#698769
I have a set of Jardine "Double Header" pipes with turnout mufflers. They sound great - good rumble but not too loud. Not sure about performance. I did mine for looks. I had an old crappy rusted out 4 into 1 before going with these, which I bought from someone on KZR. They were pretty ratty but steel wool and time fixed them up nice.
Attachment KIMG0346-2.jpg not found
As far as I know Jardine made similar models for Hondas called the "spaghetti' pipe. That's about all I know.
76' KZ900
00' KLR650
82' XV920 Virago
74' Ironhead Sportster
  • PDXDave
15 Nov 2015 10:22
#698770
Mines a PMC and aside from no instructions and incorrectly numbered head pipes, it went together without a hitch. Beautiful build quality and fit.
I can't wait to get her dialed in and hear it.
  • jenkrider
15 Nov 2015 10:22
#698771
That PMC system looks really nice by the way! Costly, but very nice. Goose as in Jim Goose?
76' KZ900
00' KLR650
82' XV920 Virago
  • PDXDave
15 Nov 2015 10:41
#698772
Yes sir
