Cam Journal Wear
  • razmo99
  • razmo99's Avatar Topic Author
Re: Cam Journal Wear
18 Oct 2015 18:59
#695136
Yep that is exactly what it is.
- Z500 B4
-GPZ900R A9-10 ish
  • razmo99
18 Oct 2015 23:50
#695141
Here are some photos
Attachment DSC00894.jpg not found
Attachment DSC00895.jpg not found
- Z500 B4
-GPZ900R A9-10 ish
  • razmo99
18 Oct 2015 23:55
#695142
Attachment DSC00897.jpg not found
Attachment DSC00898.jpg not found
Attachment DSC00899.jpg not found
Attachment DSC00900.jpg not found
Attachment DSC00901.jpg not found
Attachment DSC00902.jpg not found
- Z500 B4
-GPZ900R A9-10 ish
  • razmo99
19 Oct 2015 00:01
#695143
Attachment DSC00903.jpg not found
Attachment DSC00904.jpg not found
Attachment DSC00913.jpg not found
Attachment DSC00914.jpg not found
Attachment DSC00905.jpg not found
Attachment DSC00906.jpg not found
- Z500 B4
-GPZ900R A9-10 ish
  • razmo99
19 Oct 2015 00:04
#695144
Attachment DSC00907.jpg not found
Attachment DSC00908.jpg not found
Attachment DSC00910.jpg not found
Attachment DSC00911.jpg not found
Attachment DSC00912.jpg not found
- Z500 B4
-GPZ900R A9-10 ish
  • loudhvx
  • loudhvx's Avatar
19 Oct 2015 07:05 - 19 Oct 2015 07:08
#695193
Those parts look pretty good to me. All of the cams and caps (across maybe a dozen motors or so) I've seen, haven't looked any better. It is just surprising to me that the journals would be below their limit. If they are, at least the wear is even. That being the case, I wouldn't expect the cams to be so noisy.
Last edit: 19 Oct 2015 07:08 by loudhvx.
  • Kapahulu
  • Kapahulu's Avatar
19 Oct 2015 08:31
#695204
loudhvx wrote: Those parts look pretty good to me. All of the cams and caps (across maybe a dozen motors or so) I've seen, haven't looked any better. It is just surprising to me that the journals would be below their limit. If they are, at least the wear is even. That being the case, I wouldn't expect the cams to be so noisy.
Yup keep riding it.
2strokeworld.com
  • bountyhunter
  • bountyhunter's Avatar
19 Oct 2015 09:33
#695208
razmo99 wrote: The compression is good
It does leak some oil some at the bottom end and some at the left side of the cylinder head were the oil gallery is.
It also occasionally shift out of gear for 2nd under heavy load. A neutral can also be found between 5th and 6th gear, soon after it will slip into either.
When it was new, my 750 twin used to frequently find a neutral in between fourth and fifth gear. I would shift into fifth and let the clutch out and it would not be in any gear (engine rev). Then I would shift again and it would go into fifth with a CRUNCH.
