Redline
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
Redline
23 Sep 2015 09:23
#691517
Is there any reason to fear the redline ? :ohmy:
1982 KZ1100-A2/1170 sleeper 😀
Re: Redline
23 Sep 2015 09:32
#691518
The fear should be directed toward exceeding the redline. There was a guy on another forum who said he regularly ran his KZ650 up to 11,000 rpm. It caught up with him when the engine crashed. He didn't clarify if the valves and pistons clashed or if the rods stretched a little or what, but the failure was catastrophic to the engine's internals.
On a stock engine it makes no sense to rev it beyond the redline because there is precious little power present at those high rpm. As an example, my KZ650 horsepower tops out at 64 @8,500 rpm. The redline is 9,000 rpm, but at that engine speed the horsepower has already started dropping and it drops very quickly beyond the redline. So shifting at redline or just before it produces the fastest acceleration. Ed
  • Kwaker2000
  • Kwaker2000's Avatar
Re: Redline
23 Sep 2015 09:33
#691519
only if you want to destroy your engine
  • pete greek1
  • pete greek1's Avatar
Re: Redline
23 Sep 2015 09:50
#691522
& If you're into the redline area & your transmission doesn't engage in the gear you're shifting in, your motor will rev well beyond the redline limit, & KABOOM, something's gonna give,
Pete
  • daveo
  • Premium Member
  • Premium Member
Re: Redline
23 Sep 2015 09:53
#691523
Kwaker2000 wrote: only if you want to destroy your engine
...but doesn't the owner's manual recommend to not exceed 3000 rpms before shifting :laugh:
  • daveo
  • Premium Member
  • Premium Member
Re: Redline
23 Sep 2015 10:08
#691527
pete greek1 wrote: & If you're into the redline area & your transmission doesn't engage in the gear you're shifting in, your motor will rev well beyond the redline limit, & KABOOM, something's gonna give,
Pete
The Dynatek 2000 has an adjustable rev limiter in 500 rpm increments starting at 8500, which is redline on my tach...and my engine has no problem going there. Should I set it to 9000-9500 for the extra breathing room?
  • jackleberry
  • jackleberry's Avatar
Re: Redline
23 Sep 2015 10:08
#691528
If Kawasaki didn't want me to hit 9000RPM, they should have given me a 6th gear...
1997 KZ1000P (P16)
2001 KZ1000P (P20)
  • daveo
  • Premium Member
  • Premium Member
Re: Redline
23 Sep 2015 10:13
#691529
jackleberry wrote: If Kawasaki didn't want me to hit 9000RPM, they should have given me a 6th gear...
:laugh: Sixth gear sure would be nice...
  • jackleberry
Re: Redline
23 Sep 2015 10:15 - 23 Sep 2015 10:17
#691531
To give a little more anecdotal information: In the past I've had a few missed shifts on my stock P16, revving up to 10k with no damage. I've also recently run it at 9k for periods of 10 minutes straight (was trying to free a stuck ring [it worked!]). Again, no damage. There's not much power above 9k though. These KZ1000J motors really seem to want to run at 6 to 8k--I'm talking cruising RPM. Anything under 4k is lacking in torque and anything between 4k and 5k buzzes like crazy.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
Last edit: 23 Sep 2015 10:17 by jackleberry.
  • KZB2 650
  • KZB2 650's Avatar
Re: Redline
23 Sep 2015 10:19 - 23 Sep 2015 10:24
#691533
There is a black top we use for our 1/4 mile, 1/3 mile and 1/2 runs and I've ran them at least a dozen times a year for 35 years hitting 9,200 to 9,300 before power shifting with no Ill effects......... hit 9,500 more a few times in 5th at the 1/3rd and 1/2 mile with a little tale wind and on a cool day with a 9,000 red line.......... with the 750 cams and APE springs it wants to pull hard to 9,500 or a little over now ........ have only done it a few times since it only had 900 miles on it with the the 700cc pistons....... next year I plan on getting the 29mm smooth bores dialed in and back on and see what it'll really do. :woohoo:
I'd set the limiter to at least 9,000 shame it could'nt go to 9,200 ......... 9,500 might be a little high but see what others think ...... you don't want it cutting out right when the fun starts. ;)
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 23 Sep 2015 10:24 by KZB2 650.
  • daveo
  • Premium Member
  • Premium Member
Re: Redline
23 Sep 2015 10:19
#691534
jackleberry wrote: To give a little more anecdotal information: In the past I've had a few missed shifts on my stock P16, revving up to 10k with no damage. I've also recently run it at 9k for periods of 10 minutes straight (was trying to free a stuck ring [it worked!]). Again, no damage. There's not much power above 9k though. These KZ1000J motors really seem to want to run at 6 to 8k--I'm talking cruising RPM. Anything under 4k is lacking in torque and anything between 4k and 5k buzzes like crazy.
Amazing, when fine tuned.
  • daveo
  • Premium Member
  • Premium Member
Re: Redline
23 Sep 2015 10:23
#691535
KZB2 650 wrote: There is a black top we use for our 1/4 mile, 1/3 mile and 1/2 runs and I've ran them at least a dozen times a year for 35 years hitting 9,200 to 9,300 before power shifting with no Ill effects......... hit 9,500 more a few times in 5th at the 1/3rd and 1/2 mile with a little tale wind and on a cool day with a 9,000 red line.......... with the 750 cams and APE springs it wants to pull hard to 9,500 or a little over now ........ have only done it a few times since it only had 900 miles on it with the the 700cc pistons....... next year I plan on getting the 29mm smooth bores dialed in and back on and see what it'll really do. :woohoo:
Ye-ha!
The following user(s) said Thank You: KZB2 650
