twins forum and setting idle
Re: Re:Re: twins forum and setting idle
29 Aug 2015 05:58 - 29 Aug 2015 05:59
#687580
See info in the following link:
www.zedder.com/Info/82%20KZ305-B1%20CSR.htm
Valve Clearance Cold
Intake 0.14 - 0.19 mm
Exhaust 0.21 - 0.26 mm
Valve Adjustment Method -- Rocker arm screw
Would suggest aiming for the larger clearances within the ranges specified, because the clearances typically are expected to gradually reduce as the engine accumulates mileage.
Good Fortune! :)
Last edit: 29 Aug 2015 05:59 by Patton.
  • 82KZ305Belt
  • 82KZ305Belt's Avatar Topic Author
29 Aug 2015 06:46
#687583
I was wondering about valve clearance too. How often should one have to adjust it though? I've ridden this bike 6000 miles in 5 years, and I did adjust the valves 2-3 years ago. So maybe 2500 miles?
And I had no luck getting it right until used a simple an alternative method that was described on the Twins Forum which I can't access now. Maybe I can find it on the wayback machine... :(
81 KZ650 CSR
77 KZ650B (not in my paws yet)
82 KZ305 CSR
  • 82KZ305Belt
29 Aug 2015 08:52
#687602
Actually I found that info in post 454272 in my previous thread here
kzrider.com/forum/2-engine/454024-valve-...ot-be-there?start=20
which was actually over 4 years and 4000 miles ago. So much for memory; I have none. I'm going to have to relearn the 5 minute procedure again because I've forgotten that too.
81 KZ650 CSR
82 KZ305 CSR
