Engine knocking/grinding
  • Bozo
  • Bozo's Avatar
  • Ride it like u stole it
Re: Engine knocking/grinding
06 Aug 2015 18:30
#684709
Agree, Starting to sound like the chain and sprockets, keep in mind that the gear shaft is still driven in neutral and the engine off but that's easy to check by seeing if there is ANY play on the shaft by push sideways on the sprocket,
  • brianpclarke
  • brianpclarke's Avatar Topic Author
06 Aug 2015 19:37
#684729
No play that I can tell in the sprocket. Checked that out. I keep messing with the chain and its rubbing on the chain guard. It's being weird. Anyways...
So... I guess I will start checking things off in order as soon as I get settled starting with the wheel bearings and chain... then moving on to the gearbox bearing.
Thanks for the help guys!
-Brian
1977 KZ650C
1976 Kz900 LTD
  • Tyrell Corp
  • Tyrell Corp's Avatar
07 Aug 2015 07:22
#684775
Dodgy chain and sprockets when bad you can hear just rolling the bike along at walking pace. If the difference between the 'tight' spot and the loose part of the chain is a lot that is a good indication too. Chains often wear unevenly, with a tight spot.
  • aek
  • aek's Avatar
07 Aug 2015 09:40
#684787
Agree with Tyrell Corp. except I would put the bike back on it's center stand, remove the sprocket cover again, and run the chain through by turning the rear wheel by hand. As soon as you see and hear the chain contact the chain guard your search is over.
Good luck.
Art
1980 750-4 LTD original owner
  • missionkz
  • missionkz's Avatar
07 Aug 2015 10:13
#684789
Want to scare yourself some time? Put the bike on the center stand, start the engine put it in first, second then fifth gear at street RPMs and watch your chain slap all over the place!
If you have a bad chain, you will see it do all kinds of ugly stuff.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • bluezbike
  • bluezbike's Avatar
07 Aug 2015 13:55
#684806
brianpclarke wrote: Hey guys!
At about 3500 starting hearing a terrible metal on metal grinding at about 30mph. It doesn't increase or decrease with revs and remains pretty constant... but goes away coming down at lower speeds.
I am thinking it cannot be the chain if the sound remains constant above 30 mph. I am leaning towards wheel bearings or trans bearings,as Ed mentioned try to isolate the direction of the noise.
79 KZ 1000 LTD
