1978 kz650c starting problems
- nch_2018
- missionkz
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
- Thank you received: 2829
The factory service manual provides instructions on the various maintenance procedures and schedules for your bike, procedures for diagnosing problems, proper torque values for the various fasteners (VERY IMPORTANT), and insight into how each system on your bike works even if you are not repairing that system. Studying the manual before you attempt performing service on your bike will impart an understanding of the system you are working on which will increase the odds of success.
The manuals usually are readily available for most models on eBay and other sources; but be sure to get one that has your specific year and model in it as there are differences between the various KZ650 models. I do not recommend Clymers, Haynes, or other aftermarket manuals as I have seen instances where they provide inaccurate advice. You may decide to use those to supplement the factory manual, but in my opinion they are not a suitable substitute. If you have trouble finding one for your model ask us to help. Ed
- Thank you received: 2234
The starter clutch can be a bit of a bear. Since you have a kick starter, I'd recommend taking care of all the routine maintenance first. If you then discover other reasons to tear into the engine, they can all be dealt with at the same time.
www.kzrider.com/forum/21-tools/598060-jis-screwdrivers#672883
- ezrider714
- Thank you received: 38
This is a sure sign you are not getting fuel to/or thru the carbs
Make sure fuel is coming out of the petcock, if it is then follow TexasKZ's advice in setting the fuel level in the carb bowls....
I also wouldn't worry about the electric start until getting the bike up and running
78 KZ650SR Mine since 79
4-1 Mac Jet Hot coated since mid 80's
Dyna Coils
Saddlebags (I ain't skeered of going nowhere)
- Tyrell Corp
- Thank you received: 261
Starter clutch sounds like screeching, a really nasty sound. I have a video of it on mine but can't upload it, but it is an unmistakable noise. Luckily you have a kick starter, something bereft from the 550's, so maybe put that lower on your to-do list.
Starter fluid spray is a good diagnostic and get you out of trouble fix, but not to be used too often as it washes oil off the bores. it should run all day on that if you needed to prove a point ( and it would probably only last a day)
So I'm thinking forget fuelling -for now and look towards ignition. Get a multimeter and search through some old posts here then see what you find. Good luck!
- missionkz
Well, I for one disagree here. I think carbs and the fuel delivery is still the problem and needs to be addressed first.Tyrell Corp wrote: ...
15 yrs old or not, it's a learning curve and I think this owner is up to it.
My first bikes were home made 1 1/2hp Briggs and Stratton "mini bikes" on Stingray bicycle frames!!
My first real motorcycle was a mid 60's Suzuki X6 Hustler... which hauled ass!!!
Bruce
1977 KZ1000A1
- nch_2018
The vacuum port on the upper side of carb #2 should have a tube that runs to the petcock. Vacuum drawn through that tube when the petcock is in the "ON" position acts on a diaphragm which then permits fuel to flow to the carbs. In the "ON" position no fuel will flow if the engine if off or if the vacuum line is not attached. No fuel should ever flow through the vacuum line, it simply controls the petcock. To start the bike after it has been sitting the petcock should be set to the "PRI" position. If your petcock has been changed to a manually operated one the vacuum port on the #2 carb needs to be capped, and the petcock turned to "ON" when starting and running the engine.
There is a good description of the Clear Tube Method in the manual, but in the mean time here is a diagram that should help. Ed
Attachment ClearTubeDiagram-4.jpg not found
- nch_2018
- nch_2018
