KZ250 Clutch - what needs replacing.
  • Nessism
  • Nessism's Avatar
Re: KZ250 Clutch - what needs replacing.
20 Jul 2015 20:39
#681914
Irish Yobbo wrote:
OK I might need a bit more info on this. If there's more slack (let's say 5mm of extra cable) then my clutch lever will be loose (by a couple of cm). As I understand it, when the clutch is 'off', there should be no pressure from the cable at all, so whether there is a tiny bit of slack (1mm extra cable) or more(5mm extra cable) will make no difference to the clutch apart from the lever travel and the take-up point.
You are correct. Just that you need to make sure there is enough slack. Better too much than not enough. 8/10 times all you need is new stock springs and you are good to go.
