- Thank you received: 13
Kz440 Project Picture Heavy
- DobbinsCMA
What's going on with these plugs?
Attachment image-4.jpg not found
Attachment image-5.jpg not found
Attachment image-6.jpg not found
Now for an oil change and new gas. Then see if she starts with new battery. Then valve adjustment and exhaust fix. Get the brakes unstuck (maybe just the front or rear) and drive to get new tires put on!
'80 Kz1000B4
MTC 1075 .375 webcams Mikuni RS34
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
- DobbinsCMA
Attachment image-10.jpg not found
Also just saw the new Mad Max...wow. Old one had a Kz1000 but I didn't see one with this.
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
- Thank you received: 2829
Nothing wrong with those plugs as long as you plan to install them in a Ford. :laugh: Ed
- DobbinsCMA
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
- rstnick
- Thank you received: 377
I suspect your new plugs may need the tops removed to fit you spark plug caps.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- DobbinsCMA
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
- rstnick
I have different spark plug wrenches to remove the plugs, and some have the rubber piece inside the socket.
You have to remove the little tops on the plugs to use these sockets.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- DobbinsCMA
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
- Richardb98
- DobbinsCMA
Attachment image-11.jpg not found
Attachment image-12.jpg not found
Attachment image-13.jpg not found
Attachment image-14.jpg not found
Attachment image-15.jpg not found
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
- Randombeat
- 0 to 100 real quick...
- Thank you received: 23
1980 KZ750H LTD-- pods-- vance & hines 4-1 --speedo/tach/blinker/switch deletes -- brat style
