Help with my 81' kz440
Re: Help with my 81' kz440
25 Apr 2015 15:43 - 25 Apr 2015 15:47
The rubber bits around the polyester caps are o-rings & should be replaced. A Harbor Freight metric o-ring kit might have a suitable size. Some auto parts stores have o-rings. nitrile or viton (not hardware store plumbing o-rings).
The bike needs a good battery to run right as it supplies the energy to fire the coils & the charging system needs to be working. If the battery is in a poor state of charge, use a good smart charger (not the bike's charging system).
Last edit: 25 Apr 2015 15:47 by martin_csr.
- Richardb98
25 Apr 2015 19:02
Damn I just got back from harbor freight. I'll get some o-rings tomorrow and update. Also I'm repairing the wire that heats up so I'll let you know the outcome of that aswell
25 Apr 2015 19:23
Replace or repair if possible damaged wires. If any terminals have to be replaced, such as the bonding lug on the frame ground wire, be sure to do a good/proper connection with the proper tools. Poorly done mash crimp connections should be avoided as they can fail from engine vibration --- you may as well do 'em right.
Also, connections become poor from oxidation over time & the po may have buggered up stuff. So you should check & clean any electrical connectors when possible. Mfolks has a good writeup somewhere for cleaning up old connections.
