Stripped rocker box bolts on KZ1000P
Re: Stripped rocker box bolts on KZ1000P
10 Feb 2015 19:23
My daughter has the option of being the So Cal distributor of Belzona. They have adhesive products that will seal a cast iron block, applied a patch to a heavy crane tire stuck in a deep mud hole, let it set, aired it up and drove it out and more. Adhesives have come a long way in the last 40 years.
- Skiprrdog
- "Are we there yet?"
10 Feb 2015 19:37
Yeah, I ordered the heli coil kit and a new cam cover gasket today...so as soon as that gets here Ill be ready to rock. :woohoo:
1983 KZ1100 A-3 Shaft
1976 KZ900
1975 H2 Triple
1984 Yamaha XJ900 Seca
1984 Harley Davidson FXRDG
#BlackBikesMatter
1976 KZ900
1975 H2 Triple
#BlackBikesMatter
10 Feb 2015 21:16
Stuff rags everywhere and suck out all the shavings.
- Skiprrdog
11 Feb 2015 08:06
That is what I was thinking, rags, plastic, and a shop vac. Definitely don't want to leave any metal shavings in there...
1976 KZ900
1975 H2 Triple
#BlackBikesMatter
1976 KZ900
1975 H2 Triple
#BlackBikesMatter
- Skiprrdog
17 Feb 2015 15:40
Well, I got the heli coils in last weekend, and cam cover/head gasket mating surfaces cleaned up and ready for the re-install, just waiting on some parts.
Quick *noob* question; I guess I did not realize I was supposed to take off the cam chain tensioner cap and spring prior to removing the cam cover. I have not moved or turned over the engine in any way, soooo, is this a problem?
1976 KZ900
1975 H2 Triple
#BlackBikesMatter
1976 KZ900
1975 H2 Triple
#BlackBikesMatter
